Date/Time: Sat, 21 Dec 2024 17:53:44 +0000
extension trial
View Count: 934
[2015-05-15 19:18:38] |
User412599 - Posts: 6 |
Hello. Can I ask you on the extension trial? Next Opening fxcm account. regards. |
[2015-05-15 21:14:18] |
Sierra Chart - Max - Posts: 5756 |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2015-05-15 21:25:25] |
Thank you, Regards
[2015-07-27 10:36:42] |
Hi, I am not efficient in english. I want to custom the studies , but how can I open codes of studies availables ? Regards |
[2015-07-27 16:43:24] |
Refer to the documentation here about where to find the available Source Code: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html#CodeAndExamples Sierra Chart Support |
