Date/Time: Sun, 22 Dec 2024 17:26:00 +0000
Text Display for study from chart: need 3 number after the " ."
View Count: 1040
[2015-05-15 15:40:28] |
sierra28 - Posts: 120 |
i display study "% change" in a chart which is display with 3 numbers after the "." and i use the study "Text Display for study from chart" to display value of "% change" in another chart. Unfortunately this value is display only with 1 number after the "." while original "%change" study is with 3 digits. thanks |
[2015-05-15 17:27:43] |
Set the Value Format setting for the Text Display for Study to the number of decimal places that you require.
