Date/Time: Thu, 17 Sep 2026 14:28:12 +0000
Using several SC instances -> Data download in all or just one instance?
View Count: 1147
| [2015-05-15 09:16:54] |
| tobi - Posts: 351 |
I have three SC instances running. In each instance I'm using the same, 13, underlyings. Only the chartsbooks are different in the instances. I'm using 5 minute up to weekly charts. Data feed = FXCM. Would you recommend downloading the 13 underlyings in each instance (1, 2 and 3) or downloading the 13 underlyings just in instance 1 and using remote data from instance 1 for instance 2 and 3? I'm running a 6 core CPU and 16 GB RAM in my system. |
| [2015-05-15 10:15:25] |
From our perspective, we do not think this really matters either way.
