Date/Time: Sun, 22 Dec 2024 17:56:08 +0000
rotate sierrchart
View Count: 1017
[2015-05-14 19:08:59] |
doctor10 - Posts: 78 |
Is there a way to rotate sierrachart 90 degrees?
[2015-05-14 19:35:20] |
No. Although your video card software should be able to rotate the contents of a display.
