Date/Time: Tue, 15 Sep 2026 11:43:15 +0000
Incorrect price movement
View Count: 1107
| [2015-05-14 16:34:59] |
| User56213 - Posts: 8 |
I am having following problem wih my chart trading SCH. I am describing it on following pics. First one is opened position, short, on price 4473.25, everything´s ok. Second picture, 2-3 secs after, price moved down 1 tick (0.25) and moved with itself (!) also the opening price line (!!), to 4473.15. That price move even doesn´t exist, minimum move e-mini Nasdaq is 0.25 point. I even cannot hover my cursor on the price, the movement is incorrect. Thank you for you assistance how to solve it. Regards Robert |
| [2015-05-14 17:52:55] |
What you see is the Trade Position Average Price provided by Interactive Brokers. If you have a question about it, contact Interactive Brokers. For more information, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#HowAvgPricePositionsCalcUsed In the case of Interactive Brokers, with the newer versions of Sierra Chart, the Interactive Brokers provided Position Average Price always is used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-14 17:53:36
