Date/Time: Sun, 22 Dec 2024 17:38:08 +0000
Is this bad data?
View Count: 878
[2015-05-14 15:04:09] |
arrow - Posts: 52 |
I have an issue when markets move fast. I use a Renko bar with wicks, when the market speed picks up I get a lot of false bars. The market might move up 5 or so bars in a few seconds but what I see displayed is an up and down move several times. For example CL at 7:30 upon inventory report. I also get false high and lows. The bar wick will show a high sometimes 2 or 3 ticks above the actual high. All of this clears up once I delete and download data. Is this from slow or bad data or SC? I'm using Rithmic for data. |
[2015-05-14 17:53:55] |
This is impossible for us to comment on unless we know the Renko bar settings, can see the underlying data, and actually see what you are seeing. If you see something which does not look right with the chart bars, then reload the chart with Chart >> Reload and Recalculate. Most likely the problem is you do not have a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
