Date/Time: Sun, 22 Dec 2024 17:23:45 +0000
Are Ticks Limited?
View Count: 852
[2015-05-13 18:38:50]
CustomIndicators - Posts: 126
I have a range of charts in my chartbook. They are all set as Intraday charts, and the Bar Period in the Chart Settings is set to Number Of Trades Per Bar.
The charts are all showing correctly up till the biggest charts. For instance, my 32000 tick, 64000 tick and 128000 tick all look different, but the 256000, 512000, and 1024000 all look exactly the same. How can I fix this? I need those bigger charts to display properly.
[2015-05-13 19:33:25]
As explained here:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: General Information and Related Settings
uncheck New Bar at Session Start:
[2015-05-14 03:08:50]
Thank you. That was exactly what I needed! :D
