Date/Time: Tue, 22 Sep 2026 14:05:37 +0000
Using same spreadsheet trading system on multiple different instruments
View Count: 1363
| [2015-05-13 17:27:19] |
| User911705 - Posts: 89 |
I have completed a spreadsheet type auto trading system. I currently have the spreadsheet connected to the spreadsheet study in a 30 min ES chart. Now I wish to implement the same system on numerous other instruments. How best to do this? I assume I need a unique spreadsheet (or at least a unique sheet) for each instrument implemented, but I'm not sure how to do this exactly. Thanks for your help! |
| [2015-05-13 17:37:48] |
| Sawtooth - Posts: 4354 |
If the other instruments are in the same chartbook, add the Spreadsheet System for Trading study to each chart and give all the same name in the Spreadsheet Name field. Each chart will have its own sheet. If each instrument is in its own chartbook, the spreadsheet names should be unique, assuming you would have them open concurrently. |
| [2015-05-13 23:31:19] |
Thank you, tomgilb!
| [2015-05-14 18:45:05] |
The general method to do this is to create a Study Collection containing the trading system studies and apply it to other charts. Here are instructions: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-14 18:45:21
