Date/Time: Fri, 11 Sep 2026 10:26:31 +0000
Interactively Drawing Volume Profiles - VWAP
View Count: 2086
| [2015-05-13 15:17:08] |
| User78442 - Posts: 260 |
I use the interactive VP's alot, it is a very strong SC feature - Is there any simple way to show the VWAP on the profile? I tend to profile swings/areas of balance and want to get the VWAP for a particular set of bars. Help on this appreciated! |
| [2015-05-13 18:59:07] |
You need to use the Volume Weighted Average Price study.
| [2015-05-14 05:01:24] |
How do I set this up this with a developing, Interactive VP?
| [2015-05-14 05:02:36] |
OK we understand. You are asking about a volume profile which is interactively drawn. For this, there is no support for what you need.
| [2015-05-14 05:20:25] |
Is this possible to add to the VP options? I think it would benefit a large number of users.
