Date/Time: Sat, 12 Sep 2026 04:39:55 +0000
[User Discussion] - bid v ask meter
View Count: 3326
| [2015-05-13 14:08:54] |
| User60518 - Posts: 106 |
Hi, Not sure how practical this would be to create or if a tool/study exists. Is there a kind of gauge that can calculate the bid v ask volume, but not as in volume at price - one that can count each over time - that can be started/stopped or reset when wanted. for example you go short at 2105.00 on the ES, click start and it draws a kind of horizontal bar chart split between bid & ask and adds up the bid/ask volume? would be a good tool to assist with reading the flow of orders I have attached a crude picture to better explain. Thanks |
| [2015-07-19 14:18:45] |
hi Just wondered if there is a setting to show bid v ask volume irrespective of price - could be for a daily chart, hourly etc. or preferably at user specified start/end time. CHeers |
| [2015-07-20 01:03:22] |
| mkata - Posts: 103 |
If you're interested you can check out OrderFlowEdge under Products. The have a trade delta gauge that sounds like what you're looking for. http://ofetoolbox.kajabi.com/sp/26526-non-ofe-members-trade-delta |
| [2015-07-24 08:16:53] |
Thanks Mkata - wondered if there was something already availablein Sierra's studies - or a setting that can be applied to number bars for the same effect?
