Date/Time: Sun, 22 Dec 2024 18:38:01 +0000
Chart shortcut menu
View Count: 938
[2015-05-13 13:01:50] |
pismo10 - Posts: 159 |
When i right click on a chart this menu comes up. I want Chart Values/Crosshair to be the default choice. For example when i choose rectangle, when i am done drawing the rectangle i want it to go back to Chart Values/Crosshair again rather than stay on rectangle. Had it this way until I upgraded, now issues. 1254 DTNIQ Thanks |
[2015-05-13 16:56:36] |
Sierra Chart - Max - Posts: 5756 |
Refer to the documentation here to update the Chart Shortcut Menu: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeChartShortcutMenu And Add the Chart Values/Crosshair tool. You will also need to set Global Settings >> Tool Settings >> General >> After Single Tool Use Change To to Chart Values. Sierra Chart Support Date Time Of Last Edit: 2015-05-13 16:59:36
[2015-05-13 17:03:43] |
No help
[2015-05-13 17:21:37] |
You need to set Global Settings >> Tool Settings >> General >> After Single Tool Use Change To to Chart Values.
Sierra Chart Support Date Time Of Last Edit: 2015-05-13 17:23:32
