Date/Time: Fri, 11 Sep 2026 09:56:34 +0000
Trade Dom
View Count: 1263
| [2015-05-13 10:09:27] |
| User783053 - Posts: 1 |
I only see the left side and not the right side with the price ladder etc....How do I get the ladder to show? Thanks |
| [2015-05-13 11:27:53] |
We need to see an image of the Trade DOM. Refer to the instructions here to post it: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-14 21:05:18] |
http://www.sierrachart.com/image.php?l=1431598331801.png Did as per instructions but no Dom so went back and selected Dom window 'always on top' otherwise it will not show? http://www.sierrachart.com/image.php?l=1431597708708.png
Above is what you requested. I have found that I can see the right side/price ladder of the Dom from the File menu but I still cannot see it by clicking on the chart where it only shows the left side. Also how do I remove the 50% on the price ladder as per in the image above? Sierra Chart Support Date Time Of Last Edit: 2015-05-14 21:43:16
| [2015-05-14 21:47:21] |
What you need to do is enable Trade >> Trading Chart DOM On. Here is the complete documentation for this feature: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM To remove the percentages uncheck Global Settings >> Chart Settings >> Display Depth Percentages. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
