Date/Time: Sun, 22 Dec 2024 18:33:06 +0000
AJAX FX DATA
View Count: 874
[2015-05-13 04:35:32]
User868662 - Posts: 9
Dear customer support,
I am not happy with FXCM data particularly with the daily open, high, Low etc. is there anyway i can use AJAX Fx data or any other fx data? Will FXCM FIX trading data give me the correct open, High, Low etc?
Thanks,
Selva
[2015-05-13 05:41:41]
There is an alternative to the FXCM daily data.
Go to Chart >> Chart Settings and change the Symbol. Include a ^ character in front of the symbol. Example:
^EURUSD
