Date/Time: Sun, 22 Dec 2024 18:22:57 +0000
Scale range on Number bar
View Count: 928
[2015-05-12 14:44:55]
JingIt - Posts: 44
Dear SC support,
I apologise to create another thread about Scale issue on number bar chart issue . I did try to reset scale to see the last price but I have to to keep an eye on a few charts to manage my position and I can't reset scale frequently when I was in the trade. My number chart is in range style so it move very quick when market really moving and I didn't have much room for these chart on my monitor, I have another number bar chart in reversal bar have the same issue.
I did record my chart to show it, when price goes to the top or bottom of chart, I can't see the last bar.
I wish SC team can adjust the constant range scale, the last price only move in 80% or 90% of the range so the last price always in view (kind of top and bottom margin)
Thank you for consideration!
screencast.com/t/O6qzyXsvcdm
beginning of video to 0:10
0:16 - 0:20 Scale setting
2:00 - 2:10
2:35 - 3:00
Date Time Of Last Edit: 2015-05-12 14:47:59
[2015-05-12 18:59:20]
In the latest release we added a 2 tick margin but that will not help if there has been any Interactive Scale Move adjustments performed on the scale.
Once you have moved the scale, the price bars have then been offset from the default and the scale adjustment Sierra Chart will make to keep the high and low in view will not keep the high or low within view.
Date Time Of Last Edit: 2015-05-12 18:59:29
[2015-05-13 00:42:50]
JingIt - Posts: 44
Thank you SCE, I appreciate that, work well in 1254 version. I'm very happy.
However, the volume profile width (beside TPO profile) was contracted compare to previous version
image1253.png / V - Attached On 2015-05-13 00:39:33 UTC - Size: 7.98 KB - 352 views
image1254.png / V - Attached On 2015-05-13 00:39:47 UTC - Size: 7.81 KB - 339 views
[2015-05-13 00:44:27]
There is a new setting in the TPO Profile Chart inputs to control the minimum number of bars for the volume profile. You just need to increase that.
