Date/Time: Mon, 28 Sep 2026 01:59:22 +0000
data
View Count: 1061
| [2015-05-12 11:53:58] |
| User705641 - Posts: 38 |
I have just renewed access to sierra charts package 5, do I need to arrange a separate forex and CFD data feed to use the charts. AT present I am not trading off the charts.
| [2015-05-12 16:57:10] |
For Real-Time Forex and CFD Data, you can use the Sierra Chart Real Time and Historical Forex and CFD Data Service: Sierra Chart Real Time and Historical Forex and CFD Data Service Did you restart Sierra Chart after making the payment? If after a restart you are still not able to connect to the above data feed, then follow the Forced Login steps below: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support Date Time Of Last Edit: 2015-05-12 19:54:53
| [2015-05-12 19:57:58] |
A couple corrections were made to the prior post. Also, in your regards to your other posting, no Sierra Chart service package includes the Sierra Chart Real-time and Historical Exchange Data Feed. That is a separately paid for service: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
