Date/Time: Sun, 22 Dec 2024 18:46:13 +0000
Attached Order Question
View Count: 844
[2015-05-12 04:48:52] |
Sierra Chart - Max - Posts: 5756 |
I'm using 1 lot on CL, 7 target, 7 stop. I would like stop to go to -4 if price goes +4 ticks, and stop to go to BE if price goes +6 ticks. Can you tell me how to do it, please? Sierra Chart Support |
[2015-05-12 18:56:32] |
Refer to the attached screenshot for the Targets tab configuration for this. Also make sure to enable Use Attached Orders on the Main tab. Sierra Chart only supports one Move to Breakeven action. Here is the documentation for the Move to Breakeven for Stops functionality: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#MoveBreakevenForStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
TradeWindow2015-05-13_065347.png / V - Attached On 2015-05-12 18:55:36 UTC - Size: 6.74 KB - 343 views |
