Date/Time: Thu, 04 Jun 2026 07:39:52 +0000
Export does not work properly
View Count: 1279
[2015-05-11 19:33:19]
User386687 - Posts: 53
I have a continuous contract "FDAX0615-EUREX [CBV]" on my chart (from 2009 up to the recent data) and I can view it without any problems. But when I try to export that chart to a text file it only writes something about latest 2 months not the whole 5 years.
What could be the problem ?
Date Time Of Last Edit: 2015-05-11 19:34:50
[2015-05-11 20:12:11]
You need to use this command instead:
https://www.sierrachart.com/index.php?page=doc/doc_EditMenu.html#ExportBarDatatoText
[2015-05-12 05:09:02]
This is exactly the command (found in Chart's Edit Menu) what I am using.
[2015-05-12 05:18:13]
Make sure you are on the current version of Sierra Chart. This is a new command named Edit >> Export Bar Data to Text File.
[2015-05-12 06:51:39]
SC updated and now I can see that option.
I tried it but for some reason it did it by the 5 minute bars not 200 tick bars which is configured on the chart.
How can I fix this ?
Date Time Of Last Edit: 2015-05-12 06:51:57
[2015-05-12 18:42:36]
We do see one minor problem where the last bar is not written to the file and that will be corrected in the next release.
However when using Edit >>Export Bar Data to Text File, the outputted data represents each bar. Here is an example of output for a 500 trades per bar chart:
Date, Time, Open, High, Low, Last, Volume, NumberOfTrades, BidVolume, AskVolume
2015/5/8, 16:09:32.34, 2108.25, 2108.50, 2108.00, 2108.25, 2115, 500, 1227, 888
2015/5/8, 16:10:04.24, 2108.25, 2108.75, 2108.00, 2108.25, 2059, 500, 813, 1246
2015/5/8, 16:11:28.2, 2108.25, 2108.50, 2107.75, 2108.25, 2391, 500, 1212, 1179
2015/5/8, 16:12:23.38, 2108.25, 2108.25, 2107.50, 2108.25, 2875, 500, 1452, 1423
2015/5/8, 16:13:31.36, 2108.25, 2108.50, 2108.00, 2108.50, 2191, 500, 1210, 981
2015/5/8, 16:14:11.6, 2108.50, 2108.75, 2108.00, 2108.50, 3423, 500, 1720, 1703
The functionality definitely works correctly.
Date Time Of Last Edit: 2015-05-12 18:43:47
[2015-05-12 19:38:52]
Now I understand what is going on.
The end of the file starting from 2013/1/4 is 200 tick bars (as my chart is) but before that it shows only 5 minute bars.
So it seems you do not have a tick data for the FDAX futures available until that date.
If this is the case then problem solved ;)
Date Time Of Last Edit: 2015-05-12 19:39:24
[2015-05-12 19:42:55]
Yes, this is probably the case.
