Date/Time: Sun, 22 Dec 2024 18:26:20 +0000
Swing marker
View Count: 1154
[2015-05-11 19:31:57] |
vectorTrader - Posts: 86 |
I am trying to use the swing marker and I cannot get the arrow to stay snapped to the high/low. When I try t, the arrow adjusts to the top of the screen and does not remain points to the high or low. http://www.sierrachart.com/image.php?l=1431372662448.png |
[2015-05-12 03:38:35] |
What is the exact name of the drawing tool you are using?
