Date/Time: Sun, 22 Dec 2024 18:08:58 +0000
Number Bars in ES, OEC broker feed
View Count: 891
[2015-05-11 15:06:30] |
User60579 - Posts: 41 |
Almost everyday the same time, about one hour from ES cash open, my numbers bars stops printing for a while only in ES? After a while it works again... They always work for DAX and FESX. My normal ES charts work good. Do you have any idea why this happens? Cheers |
[2015-05-11 15:15:14] |
User85491 - Posts: 3 |
I have this problem too, I think OEC data feed have problem with flow and speed in rush but important time, its same with IB. I am not very happy with OEC. Probably I change broker. Ask 5 usd /RT/ commisions and does not solve this problem its not a sign of good broker. They want commisions, no new investments.
[2015-05-11 15:20:27] |
Refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
