Date/Time: Fri, 22 Nov 2024 23:37:08 +0000
Keyboard-shortcut on F1 key
View Count: 2356
[2013-06-04 11:58:02] |
AndyL - Posts: 119 |
Hi, i want to assign a shortcut on the F1 key. It works, but additionaly it launches the SC help-website in the browser. Is there a way to disable that? |
[2013-06-07 14:11:34] |
[2013-06-07 16:08:23] |
No, there is not.
