Date/Time: Sun, 22 Dec 2024 18:31:45 +0000
Problem with Percent Width For Volume Profile input
View Count: 887
[2015-05-11 06:11:24]
joeroma - Posts: 43
After upgrading from 1235 to 1252 I noticed that the width of the Volume Profile is a lot wider even though the Percent Width For Volume Profile input setting is still 20. TIA.
http://www.sierrachart.com/image.php?l=1431324139297.png
[2015-05-11 09:53:23]
This is because there is a minimum width which is used. We will make the minimum with controllable in the next release.
