Date/Time: Sun, 22 Dec 2024 18:40:16 +0000
moving averages differences
View Count: 910
[2015-05-10 00:41:15] |
doctor10 - Posts: 78 |
Is there yet a way to do moving average difference of the zero-lag MA? tnx
[2015-05-10 09:48:31] |
Yes. Use the Study Subgraphs Difference study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
