Date/Time: Tue, 07 Jul 2026 13:01:46 +0000
unhandled exception
View Count: 1988
[2015-05-08 22:52:16]
jivetrader - Posts: 410
still getting an unhandled exception after updating SC to latest version. please advise.
HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-08 15:49:04
Unable to e-mail the Alert notification due to an error. | 2015-05-08 15:49:04 *
An unhandled exception was caught in c_Chart::WindowProc. Message: 32769, wParam: 32804, lParam: 0 | 2015-05-08 15:50:09 *
An unhandled exception was caught in c_MainMDIWindow::WindowProc. Message: 273, wParam: 98340, lParam: 0 | 2015-05-08 15:50:09 *
The above has been sent to support. | 2015-05-08 15:51:01 *
HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-08 15:51:22
There was a problem sending the Message Log. Please go to http://www.sierrachart.com/?CAID= for additional support. | 2015-05-08 15:51:22 *
[2015-05-09 01:26:41]
Are you running any custom studies? Refer to help topic 17:
Http://www.sierrachart.com/index.php?page=doc/helpdetails17.html
If you still have a problem update to the latest prerelease and see if you still have the problem.
[2015-05-12 07:23:17]
there are no custom studies in the chartbook. all stock SC studies.
i have tried to troubleshoot by removing a few studies at a time and i keep getting the error.
i updated to the latest prerelease and i still get the error. sierra doesn't actually hang, but the interface locks me out, i can see charts updating but i cannot access them.
do i have to rebuild my entire studies template because of this? there are a lot of studies, ported over from another chartbook and adapted to new symbols.
[2015-05-12 07:27:01]
i have just removed all charts from this CB except one. on this chart i removed all studies (studies list is blank now) and hit OK. i still get the error and the program still locks up.
[2015-05-12 08:01:09]
Are you using Spreadsheets or the Spreadsheet study? If so, we are aware of a problem which can occur which does cause an exception. We are working on it and it should be resolved tomorrow.
