Date/Time: Sun, 22 Dec 2024 18:45:50 +0000
Set lower and upper limit on graph
View Count: 1339
[2015-05-08 21:54:49] |
bskogz12 - Posts: 38 |
I have a custom graph and i want the bottom limit to be 0 and the top to be 100. Is there any way to set that so so now matter what those are the limits?
[2015-05-09 01:14:45] |
Yes. You need to use a User Defined Scale: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseGraphScaleRangeType Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
