Date/Time: Sun, 22 Dec 2024 18:05:50 +0000
Chart Linking: Use Date Range
View Count: 1082
[2015-05-08 16:05:08] |
QnReally - Posts: 181 |
Dear Support, If it doesn't already exist, would you please add support for linking charts based on the Use Date Range in addition to the Days to Load? See the attachment. This is useful when replaying or studying historical charts. Loading too many days is making the replay a little cumbersome. Thanks. |
ChartLinking.png / V - Attached On 2015-05-08 16:02:29 UTC - Size: 17.44 KB - 351 views |
[2015-05-09 00:35:26] |
We will add this capability when using the Days to Load linking.
