Date/Time: Sun, 22 Dec 2024 18:44:52 +0000
Days to Load
View Count: 1074
[2015-05-08 15:44:59] |
User35326 - Posts: 57 |
SC: When I set the days to load on an intraday chart to say 200, for example, does that require more computer resources after the chart is loaded than the same identical charts with only 90 days loaded? Or does the chart use the same amount of resources no matter how many days are loaded, once the data is loaded? The only difference being it takes longer to load the 200 day chart then it would the 90 day chart. Thanks in advance. |
[2015-05-08 17:15:05] |
There is more memory use. Also depending upon the studies being used and their settings, possibly there could be higher CPU usage, but we cannot comment on that specifically. There are just way too many variables involved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-08 17:15:21
