Date/Time: Sun, 22 Dec 2024 19:01:14 +0000
Line Properties - Labels
View Count: 984
[2015-05-08 14:47:08] |
Netz - Posts: 19 |
Hello. My Line drawing tools properties - Labels are grayed out. I can only select Opaque Label Background. Please advise on how to select the other "Show" options? Such as DIT, CV, PD, PC, etc.... Thanks! |
[2015-05-08 19:21:50] |
Refer to the documentation here for the Chart Calculator tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
