Date/Time: Wed, 09 Sep 2026 11:25:04 +0000
Visual Studio 13
View Count: 1324
| [2015-05-08 14:25:15] |
| User99735 - Posts: 234 |
Hi, Am getting 0 values in a subgraph ExitLimitIndicatorDirArray, accessed using s_ChartStudySubgraphValues ExitLimitIndicatorChartStudySubgraphValues; ExitLimitIndicatorChartStudySubgraphValues.ChartNumber = ExitLimitIndicatorChart; ExitLimitIndicatorChartStudySubgraphValues.StudyID = ExitLimitIndicatorStudy; ExitLimitIndicatorChartStudySubgraphValues.SubgraphIndex = 2; SCFloatArray ExitLimitIndicatorDirArray; sc.GetStudyArrayFromChartUsingID(ExitLimitIndicatorChartStudySubgraphValues, ExitLimitIndicatorDirArray); Have double checked that the indicator is correctly attached to chart and has SubgraphIndex 2. So to eliminate all issues, wanted to check if Visual Studio 13 is supported by SC, or I need to install vs 2010? Regards Vivek |
| [2015-05-08 17:59:27] |
We do not think this problem is affected by the particular compiler you are using. Subgraph Index is zero-based. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-08 20:22:59] |
Ok Thanks. Another query, can arrays be added to sc.StorageBlock structure, keeping the max size of 512 bytes in mind. |
| [2015-05-08 21:00:44] |
We are not clear about the question. However, sc.StorageBlock can be used like an array.
