Date/Time: Sun, 22 Dec 2024 18:53:04 +0000
ES Chart 30 mins behind
View Count: 1037
[2015-05-08 13:44:45]
User727623 - Posts: 17
I've got a demo account data connection with CTS, all other products seems to be working ok but the ES charts are following 30mins behind, it's like watching replay. From the attached screenshot you can see my system time is 14:33 but the chart last print is 14:04, even the DOM graph is active and working.
Any idea how to fix this problem?
thanks.
imageES chart.jpg / V - Attached On 2015-05-08 13:42:25 UTC - Size: 388.69 KB - 354 views
[2015-05-08 17:20:43]
This does make sense because the particular symbol you are using is a delayed symbol which will be delayed 30 minutes. For non-delayed data use this symbol:
ES.20150600.CME_Eq
This is also listed in File >> Find Symbol.
[2015-05-08 17:29:33]
solved, many thanks!
