Date/Time: Sun, 22 Dec 2024 18:33:25 +0000
VbP for TPO question
View Count: 1962
[2015-05-08 13:19:26]
User91026 - Posts: 16
this is not necessarily a question for just SC support but anyone who may know the answer. I have a VbP for TPO study attached to a TPO chart. and i have "show volume - Total Volume" enabled for the VbP. but the volume shows up in the bars and is really difficult to read. is there a way to displace/move/have the numbers show outside of the volume profile so that they are visible?
thanks.
[2015-05-08 19:07:56]
No this is not possible but it is possible to control the font size of the volume numbers.
Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#DisplayVolumeInBars
Date Time Of Last Edit: 2015-05-08 19:08:09
[2015-05-08 21:18:22]
dennismed - Posts: 62
I added VbP to my DOm and the font color to black it's now easy to read, I have not found away of changing the font color on the chart VbP > Please let me know if there is away to do so Thanks
[2015-05-09 23:18:39]
Not totally sure what you are referring to. Post an image of the chart and tell us specifically what particular text you want to change the color of.
Date Time Of Last Edit: 2015-05-09 23:18:56
