Date/Time: Sun, 22 Dec 2024 11:07:48 +0000
DOM for micro FX Futures does not work properly
View Count: 2243
[2015-06-24 04:55:21] |
We are going to be releasing a temporary solution, in the morning which will automatically correct this problem when it occurs.
[2015-06-24 22:48:38] |
This problem is finally going to be corrected now. The initial solution we thought we implemented, did not work because there was an implementation problem with it. We have now fixed this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
