Date/Time: Sun, 22 Dec 2024 18:17:38 +0000
Версия FIX протокола поддерживаемая SierraCart
View Count: 988
[2015-05-09 23:21:20] |
Yes Sierra Chart does support the FIX protocol version 4.4. But that does not mean that it can work automatically with a server supporting FIX 4.4 because there are variations in the messages used, the specific tags within those messages, with the meanings of those tags.
