Date/Time: Sun, 22 Dec 2024 18:50:10 +0000
Trade Activity Logs in 2 different computers
View Count: 1054
[2015-05-08 12:16:47] |
User386687 - Posts: 53 |
I am trading from two different locations so I have 2 copies of Sierra Chart installed in a normal PC and in a laptop. I understand that the Sierra Chart's Trade Activity Log is per installation (saved to the local disk). Is it possible to copy manually (in dos command prompt or in some text editor) activities from another computer to an another so I could see all the trade actions in 1 log ? I understand that I can save the log to a text file and view/edit it in excel as much as I want to but I would like to vew all the trades inside the SC without going to 3rd party software. Date Time Of Last Edit: 2015-05-08 12:17:36
[2015-05-08 17:57:31] |
Yes. The file is TradeActivityLog.DAT in the installation folder of Sierra Chart. You can copy that from one installation to the other. When you do make sure Sierra Chart is not running.
[2015-05-08 20:23:53] |
Thx
