Date/Time: Sun, 22 Dec 2024 16:40:25 +0000
countdown timer not working for price changes bars
View Count: 1250
[2015-05-08 06:44:03] |
User85195 - Posts: 60 |
countdown timer indicator not working with Price Change per Bar charts, instead of showing the number of price changes remained, it displays a remaining time. please instruct on how to fix this. http://www.sierrachart.com/image.php?l=1431067264999.png |
[2015-05-08 13:31:18] |
Al SC Developer - Posts: 434 |
What study and settings are you using? We do not see any issues when using the SC provided CountDown Timer study.
[2015-05-08 14:15:02] |
here is a list of the studiesI have on my chart: 1: cumulative delta bars - volume 2: volume 3: countdown timer 4. time line 5. time line the countdown timer is at default settings. Date Time Of Last Edit: 2015-05-08 14:15:35
[2015-05-08 14:44:35] |
Your image is not consistent with using default settings, so either you are using a different study or perhaps you saved your personal defaults at some point. None of the other studies are relevant. If you open a chart, set it to be a price change chart, then from studies window add "CountDown Timer" from the studies available, you will see a label like "RPC:NNN" (NNN is remaining changes) in the upper left of the chart with a fairly large font using the sc defaults. The defaults have a value of "no" for all settings except the initial positions which are 20 & 90. Please look at your settings for the study and see what is different. |
[2015-05-08 15:09:41] |
thank you, I did customize the settings and saved it as default from way back and forgot about it. the problem is caused by turning on "display continuous count down based on real time clock" option. after switching it off, the timer works properly now.
[2015-05-08 15:20:54] |
Thank you, that is helpful and we now see an issue that will be resolved in next version.
