Date/Time: Sun, 22 Dec 2024 16:40:00 +0000
NDX RUT DJIA
View Count: 1042
[2015-05-08 00:15:14] |
User584643 - Posts: 7 |
I have applied for real time data for all the indices but I am getting not data for NDX RUT or DJIA. I am logged into the SC Exchange Data and have entered both NDX RUT and $NDX $RUT and nothing shows up.
[2015-05-08 05:21:02] |
The problem is you are using the incorrect symbols. You can find the correct symbols in File >> Find Symbol. Here they are: NASDAQ: $IUXX Russell: $IUX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-08 05:21:19
