Date/Time: Sun, 22 Dec 2024 16:37:12 +0000
Need help with dom settings
View Count: 896
[2015-05-07 16:39:00] |
User48557 - Posts: 138 |
Is there a way i can get rid of the numbers in the buy and sell column? I want to keep the red and green background though.
Capture.PNG / V - Attached On 2015-05-07 16:36:08 UTC - Size: 35.46 KB - 319 views |
[2015-05-08 08:44:52] |
Yes. Here is the documentation for that: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns And here are the column descriptions: http://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartDOMColumnDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
