Date/Time: Sun, 22 Dec 2024 16:26:11 +0000
Data feed from CME
View Count: 1087
[2015-05-07 14:13:19] |
User89389 - Posts: 2 |
Hello, I need advice on how to run data from Sierra Chart for CME Exchange(35 USD for month).I tried the instruction but without result. I do not appear in the chart "M". Thank you Jaroslav |
[2015-05-07 16:43:39] |
Do you have a futures trading account? If so, with what broker or trading service? Is it with Interactive Brokers? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-07 17:41:23] |
Yes ,I have a futures trading account. I have it with Interactive Brokers . Jaroslav |
[2015-05-07 20:37:47] |
OK good, go to this page and activate one of the CME Group exchanges: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges Restart Sierra Chart and make sure to set to use Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/IB.php#SetupInstructions Charts for CME markets will then receive the data from the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
