Date/Time: Sun, 22 Dec 2024 16:16:32 +0000
EURUSD Chart will not change to different Timeframes
View Count: 1013
[2015-05-07 12:30:32]
PRV - Posts: 3
For the last day or so, I cannot change to a different timeframe on my EURUSD Chart. I originally had 3 EURUSD charts all 'linked' so when I draw on one chart the other two charts will display the same info. This has worked fine for months, I have three other markets with the same setup they all still work fine. It's only the EURUSD chart that won't change to a different timeframe. For example, it is currently set to 5 min, when I opt to change to a 1 hour view it loads the data then immediately loads data again and only shows the 5 minute.
I have removed all three EURUSD charts and then deleted all the EURUSD data in the 'Data' folder. I opened just EURUSD chart and now even with no charts linked the same result. I cannot change to any other timeframe except the 5 minute. How can I resolve this issue?
Please advise,
Thank you,
Pratap
[2015-05-07 16:42:15]
Refer to this help topic about this:
Unable to Change the Bar Time Period for Charts
[2015-05-08 13:47:49]
PRV - Posts: 3
Thanks I'll give it a try.
