Date/Time: Sun, 22 Dec 2024 16:10:22 +0000
can't get data
View Count: 1009
[2015-05-07 10:43:26] |
User40526 - Posts: 166 |
Software version: 1220 | 2015-05-07 05:32:24 Uses Old Spreadsheets | 2015-05-07 05:32:24 Usage end date: 2015-05-29 | 2015-05-07 05:32:24 Enabled for: Advanced Features. | 2015-05-07 05:32:24 Enabled for: Advanced Features 2. | 2015-05-07 05:32:24 Enabled for: Sierra Chart Historical Data Service. | 2015-05-07 05:32:24 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-07 05:32:24 Active service: CTS T4 FIX | 2015-05-07 05:32:24 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-07 05:32:24 2015-05-07 05:32:24 Local computer clock time | 2015-05-07 05:32:24 2015-05-07 10:32:24 GMT time | 2015-05-07 05:32:24 2015-05-07 05:32:24 Time zone adjusted time | 2015-05-07 05:32:24 Time difference to server time: 4 seconds. | 2015-05-07 05:32:24 Program path: C:\SierraChart\ | 2015-05-07 05:32:24 Data Files path: C:\SierraChart\Data\ | 2015-05-07 05:32:24 OS Version Number: 6.1 | 2015-05-07 05:32:24 Locale Information: C | 2015-05-07 05:32:24 Checking for new symbol settings for cts | 2015-05-07 05:32:24 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-07 05:32:24 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-07 05:32:24 Symbol settings are up-to-date for cts | 2015-05-07 05:32:25 Files to Open on Start up | Opening file: ES PROFILE RTH ONLY.cht | 2015-05-07 05:32:27 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:27 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:27 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:27 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:27 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:27 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:27 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:27 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:27 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:27 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:27 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:27 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:27 Performing historical Daily data download for symbol ESM15 starting at 0. | 2015-05-07 05:32:27 ES.20150600.CME_Eq [CBV] 15 Min #1 | Symbols used for continuous contract chart: | 2015-05-07 05:32:27 ES.20140900.CME_Eq | 2015-05-07 05:32:27 ES.20141200.CME_Eq | 2015-05-07 05:32:27 ES.20150300.CME_Eq | 2015-05-07 05:32:27 ES.20150600.CME_Eq | 2015-05-07 05:32:27 ES.20150600.CME_Eq [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-07 05:32:27 Files to Open on Start up | Opening file: ES DAILY 24 HOUR PROFILE.cht | 2015-05-07 05:32:28 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:28 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3 | Symbols used for continuous contract chart: | 2015-05-07 05:32:28 ES.20140900.CME_Eq | 2015-05-07 05:32:28 ES.20141200.CME_Eq | 2015-05-07 05:32:28 ES.20150300.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Checking for volume based rollover dates. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 5 Min #3: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:32:28 Files to Open on Start up | Opening file: ES WEEKLY PROFILE.cht | 2015-05-07 05:32:28 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:28 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2 | Symbols used for continuous contract chart: | 2015-05-07 05:32:28 ES.20140900.CME_Eq | 2015-05-07 05:32:28 ES.20141200.CME_Eq | 2015-05-07 05:32:28 ES.20150300.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Checking for volume based rollover dates. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 30 Min #2: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:32:28 Files to Open on Start up | Opening file: ES monthly profile.cht | 2015-05-07 05:32:28 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:28 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:28 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:28 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1 | Symbols used for continuous contract chart: | 2015-05-07 05:32:28 ES.20140900.CME_Eq | 2015-05-07 05:32:28 ES.20141200.CME_Eq | 2015-05-07 05:32:28 ES.20150300.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Checking for volume based rollover dates. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:32:28 ES.20150600.CME_Eq [CBV] 240 Min #1: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:32:28 Files to Open on Start up | Opening file: ES NQ LONG TERM.cht | 2015-05-07 05:32:28 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-07 05:32:28 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-07 05:32:28 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-07 05:32:28 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-07 05:32:28 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-07 05:32:28 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-07 05:32:28 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-07 05:32:28 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-07 05:32:28 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-07 05:32:28 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-07 05:32:28 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-07 05:32:28 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-07 05:32:28 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-07 05:32:28 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:29 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:29 ESM15/F.US.EPM15 [CV] Daily #1 | Symbols used for continuous contract chart: | 2015-05-07 05:32:29 ESM12 | 2015-05-07 05:32:29 ESU12 | 2015-05-07 05:32:29 ESZ12 | 2015-05-07 05:32:29 ESH13 | 2015-05-07 05:32:29 ESM13 | 2015-05-07 05:32:29 ESU13 | 2015-05-07 05:32:29 ESZ13 | 2015-05-07 05:32:29 ESH14 | 2015-05-07 05:32:29 ESM14 | 2015-05-07 05:32:29 ESU14 | 2015-05-07 05:32:29 ESZ14 | 2015-05-07 05:32:29 ESH15 | 2015-05-07 05:32:29 ESM15 | 2015-05-07 05:32:29 ESM15/F.US.EPM15 [CV] Daily #1 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-07 05:32:29 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2015-05-07 05:32:29 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2015-05-07 05:32:29 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2015-05-07 05:32:29 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2015-05-07 05:32:29 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2015-05-07 05:32:29 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2015-05-07 05:32:29 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2015-05-07 05:32:29 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2015-05-07 05:32:29 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2015-05-07 05:32:29 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2015-05-07 05:32:29 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2015-05-07 05:32:29 Date rule based rollover from NQH15 to next contract occurs at 2015-03-12. | 2015-05-07 05:32:29 Date rule based rollover from NQM15 to next contract occurs at 2015-06-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol NQM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:29 Performing historical Daily data download for symbol NQM15 starting at 0. | 2015-05-07 05:32:29 NQM15/F.US.ENQM15 [C] Daily #2 | Symbols used for continuous contract chart: | 2015-05-07 05:32:29 NQM12 | 2015-05-07 05:32:29 NQU12 | 2015-05-07 05:32:29 NQZ12 | 2015-05-07 05:32:29 NQH13 | 2015-05-07 05:32:29 NQM13 | 2015-05-07 05:32:29 NQU13 | 2015-05-07 05:32:29 NQZ13 | 2015-05-07 05:32:29 NQH14 | 2015-05-07 05:32:29 NQM14 | 2015-05-07 05:32:29 NQU14 | 2015-05-07 05:32:29 NQZ14 | 2015-05-07 05:32:29 NQH15 | 2015-05-07 05:32:29 NQM15 | 2015-05-07 05:32:29 NQM15/F.US.ENQM15 [C] Daily #2 | Waiting for historical downloads to complete with the IDs: 2, | 2015-05-07 05:32:29 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:29 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:29 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:29 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:29 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4 | Symbols used for continuous contract chart: | 2015-05-07 05:32:29 ES.20140900.CME_Eq | 2015-05-07 05:32:29 ES.20141200.CME_Eq | 2015-05-07 05:32:29 ES.20150300.CME_Eq | 2015-05-07 05:32:29 ES.20150600.CME_Eq | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Checking for volume based rollover dates. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 120 Min #4: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:32:29 Files to Open on Start up | Opening file: MY ZONES.cht | 2015-05-07 05:32:29 Date rule based rollover from ES.20140900.CME_Eq to next contract occurs at 2014-09-11. | 2015-05-07 05:32:29 Date rule based rollover from ES.20141200.CME_Eq to next contract occurs at 2014-12-11. | 2015-05-07 05:32:29 Date rule based rollover from ES.20150300.CME_Eq to next contract occurs at 2015-03-12. | 2015-05-07 05:32:29 Date rule based rollover from ES.20150600.CME_Eq to next contract occurs at 2015-06-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20140900.CME_Eq for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20141200.CME_Eq for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20150300.CME_Eq for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:32:29 Checking Intraday data file for symbol ES.20150600.CME_Eq for the date range from 2015-03-12 to 0. | 2015-05-07 05:32:29 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:32:29 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6 | Symbols used for continuous contract chart: | 2015-05-07 05:32:29 ES.20140900.CME_Eq | 2015-05-07 05:32:29 ES.20141200.CME_Eq | 2015-05-07 05:32:29 ES.20150300.CME_Eq | 2015-05-07 05:32:29 ES.20150600.CME_Eq | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Checking for volume based rollover dates. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:32:29 ES.20150600.CME_Eq [CBV] 30 Min #6: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:32:29 Files to Open on Start up | Opening file: GOLD.cht | 2015-05-07 05:32:32 Date rule based rollover from GC.20140800.CME_CO to next contract occurs at 2014-07-30. | 2015-05-07 05:32:32 Date rule based rollover from GC.20141200.CME_CO to next contract occurs at 2014-11-27. | 2015-05-07 05:32:32 Date rule based rollover from GC.20150200.CME_CO to next contract occurs at 2015-01-29. | 2015-05-07 05:32:32 Date rule based rollover from GC.20150400.CME_CO to next contract occurs at 2015-03-30. | 2015-05-07 05:32:32 Date rule based rollover from GC.20150600.CME_CO to next contract occurs at 2015-05-28. | 2015-05-07 05:32:32 Checking Intraday data file for symbol GC.20140800.CME_CO for the date range from 2014-05-29 to 2014-07-30. | 2015-05-07 05:32:32 Checking Daily data file for symbol GCQ14 for the date range from 2014-05-29 to 2014-07-30. | 2015-05-07 05:32:32 Checking Intraday data file for symbol GC.20141200.CME_CO for the date range from 2014-07-30 to 2014-11-27. | 2015-05-07 05:32:32 Checking Daily data file for symbol GCZ14 for the date range from 2014-07-30 to 2014-11-27. | 2015-05-07 05:32:32 Checking Intraday data file for symbol GC.20150200.CME_CO for the date range from 2014-11-27 to 2015-01-29. | 2015-05-07 05:32:32 Checking Daily data file for symbol GCG15 for the date range from 2014-11-27 to 2015-01-29. | 2015-05-07 05:32:32 Checking Intraday data file for symbol GC.20150400.CME_CO for the date range from 2015-01-29 to 2015-03-30. | 2015-05-07 05:32:32 Checking Daily data file for symbol GCJ15 for the date range from 2015-01-29 to 2015-03-30. | 2015-05-07 05:32:32 Checking Intraday data file for symbol GC.20150600.CME_CO for the date range from 2015-03-30 to 0. | 2015-05-07 05:32:32 Checking Daily data file for symbol GCM15 for the date range from 2015-03-30 to 2015-05-07. | 2015-05-07 05:32:32 Performing historical Daily data download for symbol GCM15 starting at 0. | 2015-05-07 05:32:32 GC.20150600.CME_CO [CBV] 5 Min #1 | Symbols used for continuous contract chart: | 2015-05-07 05:32:32 GC.20140800.CME_CO | 2015-05-07 05:32:32 GC.20141200.CME_CO | 2015-05-07 05:32:32 GC.20150200.CME_CO | 2015-05-07 05:32:32 GC.20150400.CME_CO | 2015-05-07 05:32:32 GC.20150600.CME_CO | 2015-05-07 05:32:32 GC.20150600.CME_CO [CBV] 5 Min #1 | Waiting for historical downloads to complete with the IDs: 3, | 2015-05-07 05:32:32 Files to Open on Start up | Opening file: CRUDE OIL.cht | 2015-05-07 05:32:33 Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-19. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-19. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-19. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-19. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-19. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-20. | 2015-05-07 05:32:34 Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20141200.CME_NY for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150100.CME_NY for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150200.CME_NY for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150300.CME_NY for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150400.CME_NY for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLJ15 for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150500.CME_NY for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLK15 for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:34 Checking Intraday data file for symbol CL.20150600.CME_NY for the date range from 2015-04-20 to 0. | 2015-05-07 05:32:34 Checking Daily data file for symbol CLM15 for the date range from 2015-04-20 to 2015-05-07. | 2015-05-07 05:32:34 Performing historical Daily data download for symbol CLM15 starting at 0. | 2015-05-07 05:32:34 CL.20150600.CME_NY [CBV] 5 Min #6 | Symbols used for continuous contract chart: | 2015-05-07 05:32:34 CL.20141200.CME_NY | 2015-05-07 05:32:34 CL.20150100.CME_NY | 2015-05-07 05:32:34 CL.20150200.CME_NY | 2015-05-07 05:32:34 CL.20150300.CME_NY | 2015-05-07 05:32:34 CL.20150400.CME_NY | 2015-05-07 05:32:34 CL.20150500.CME_NY | 2015-05-07 05:32:34 CL.20150600.CME_NY | 2015-05-07 05:32:34 CL.20150600.CME_NY [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 4, | 2015-05-07 05:32:34 Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-20. | 2015-05-07 05:32:35 Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-19. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-20. | 2015-05-07 05:32:35 Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20141000.CME_NY for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20141100.CME_NY for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20141200.CME_NY for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150100.CME_NY for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150200.CME_NY for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150300.CME_NY for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150400.CME_NY for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLJ15 for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150500.CME_NY for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLK15 for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:35 Checking Intraday data file for symbol CL.20150600.CME_NY for the date range from 2015-04-20 to 0. | 2015-05-07 05:32:35 Checking Daily data file for symbol CLM15 for the date range from 2015-04-20 to 2015-05-07. | 2015-05-07 05:32:35 Skipping Daily data download for symbol CLM15 since download was already done in last 24 hours. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7 | Symbols used for continuous contract chart: | 2015-05-07 05:32:35 CL.20141000.CME_NY | 2015-05-07 05:32:35 CL.20141100.CME_NY | 2015-05-07 05:32:35 CL.20141200.CME_NY | 2015-05-07 05:32:35 CL.20150100.CME_NY | 2015-05-07 05:32:35 CL.20150200.CME_NY | 2015-05-07 05:32:35 CL.20150300.CME_NY | 2015-05-07 05:32:35 CL.20150400.CME_NY | 2015-05-07 05:32:35 CL.20150500.CME_NY | 2015-05-07 05:32:35 CL.20150600.CME_NY | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Checking for volume based rollover dates. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141000.CME_NY Open price on 2014-09-19 is 92.97. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141100.CME_NY Open price on 2014-09-19 is 91.96. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -1.01. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141100.CME_NY Open price on 2014-10-17 is 83.18. | 2015-05-07 05:32:35 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141200.CME_NY Open price on 2014-10-17 is 82.4. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -0.77999997. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141200.CME_NY Open price on 2014-11-18 is 75.49. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150100.CME_NY Open price on 2014-11-18 is 75.54. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 0.050000001. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150100.CME_NY Open price on 2014-12-18 is 55.83. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150200.CME_NY Open price on 2014-12-18 is 56.17. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 0.34. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150200.CME_NY Open price on 2015-01-16 is 46.35. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150300.CME_NY Open price on 2015-01-16 is 46.73. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 0.38. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150300.CME_NY Open price on 2015-02-18 is 53.24. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150400.CME_NY Open price on 2015-02-18 is 54.05. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 0.81. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150400.CME_NY Open price on 2015-03-18 is 42.51. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150500.CME_NY Open price on 2015-03-18 is 44.5. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 1.99. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150500.CME_NY Open price on 2015-04-17 is 56.56. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150600.CME_NY Open price on 2015-04-17 is 57.97. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 1.41. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20141000.CME_NY is 319. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20141100.CME_NY is 420. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20141200.CME_NY is 498. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20150100.CME_NY is 493. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20150200.CME_NY is 459.00003. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20150300.CME_NY is 421. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20150400.CME_NY is 340.00003. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] 15 Min #7: Back adjust amount for symbol CL.20150500.CME_NY is 141. | 2015-05-07 05:32:36 Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-21. | 2015-05-07 05:32:36 Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-20. | 2015-05-07 05:32:36 Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-19. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-20. | 2015-05-07 05:32:36 Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20140700.CME_NY for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20140800.CME_NY for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20140900.CME_NY for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20141000.CME_NY for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20141100.CME_NY for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20141200.CME_NY for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150100.CME_NY for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150200.CME_NY for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150300.CME_NY for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150400.CME_NY for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLJ15 for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150500.CME_NY for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLK15 for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:36 Checking Intraday data file for symbol CL.20150600.CME_NY for the date range from 2015-04-20 to 0. | 2015-05-07 05:32:36 Checking Daily data file for symbol CLM15 for the date range from 2015-04-20 to 2015-05-07. | 2015-05-07 05:32:36 Skipping Daily data download for symbol CLM15 since download was already done in last 24 hours. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3 | Symbols used for continuous contract chart: | 2015-05-07 05:32:36 CL.20140700.CME_NY | 2015-05-07 05:32:36 CL.20140800.CME_NY | 2015-05-07 05:32:36 CL.20140900.CME_NY | 2015-05-07 05:32:36 CL.20141000.CME_NY | 2015-05-07 05:32:36 CL.20141100.CME_NY | 2015-05-07 05:32:36 CL.20141200.CME_NY | 2015-05-07 05:32:36 CL.20150100.CME_NY | 2015-05-07 05:32:36 CL.20150200.CME_NY | 2015-05-07 05:32:36 CL.20150300.CME_NY | 2015-05-07 05:32:36 CL.20150400.CME_NY | 2015-05-07 05:32:36 CL.20150500.CME_NY | 2015-05-07 05:32:36 CL.20150600.CME_NY | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Checking for volume based rollover dates. | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2015-05-07 05:32:36 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140700.CME_NY Open price on 2014-06-18 is 106.6. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140800.CME_NY Open price on 2014-06-18 is 106.06. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -0.54000002. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140800.CME_NY Open price on 2014-07-18 is 103.72. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140900.CME_NY Open price on 2014-07-18 is 102.77. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -0.94999999. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140900.CME_NY Open price on 2014-08-18 is 97.1. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141000.CME_NY Open price on 2014-08-18 is 95.14. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -1.96. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141000.CME_NY Open price on 2014-09-19 is 92.97. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141100.CME_NY Open price on 2014-09-19 is 91.96. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -1.01. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141100.CME_NY Open price on 2014-10-17 is 83.18. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141200.CME_NY Open price on 2014-10-17 is 82.4. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -0.77999997. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141200.CME_NY Open price on 2014-11-18 is 75.49. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150100.CME_NY Open price on 2014-11-18 is 75.54. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 0.050000001. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150100.CME_NY Open price on 2014-12-18 is 55.83. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150200.CME_NY Open price on 2014-12-18 is 56.17. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 0.34. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150200.CME_NY Open price on 2015-01-16 is 46.35. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150300.CME_NY Open price on 2015-01-16 is 46.73. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 0.38. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150300.CME_NY Open price on 2015-02-18 is 53.24. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150400.CME_NY Open price on 2015-02-18 is 54.05. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 0.81. | 2015-05-07 05:32:37 CL.20150600.CME_NY [CBV] #3: CL.20150400.CME_NY Open price on 2015-03-18 is 42.51. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: CL.20150500.CME_NY Open price on 2015-03-18 is 44.5. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 1.99. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: CL.20150500.CME_NY Open price on 2015-04-17 is 56.56. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: CL.20150600.CME_NY Open price on 2015-04-17 is 57.97. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 1.41. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20140700.CME_NY is -25.999941. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20140800.CME_NY is 28.000057. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20140900.CME_NY is 122.99999. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20141000.CME_NY is 319. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20141100.CME_NY is 420. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20141200.CME_NY is 498. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20150100.CME_NY is 493. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20150200.CME_NY is 459.00003. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20150300.CME_NY is 421. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20150400.CME_NY is 340.00003. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] #3: Back adjust amount for symbol CL.20150500.CME_NY is 141. | 2015-05-07 05:32:38 Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-21. | 2015-05-07 05:32:38 Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-20. | 2015-05-07 05:32:38 Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-19. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-20. | 2015-05-07 05:32:38 Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20140700.CME_NY for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20140800.CME_NY for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20140900.CME_NY for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20141000.CME_NY for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20141100.CME_NY for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20141200.CME_NY for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150100.CME_NY for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150200.CME_NY for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150300.CME_NY for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150400.CME_NY for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLJ15 for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150500.CME_NY for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLK15 for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:38 Checking Intraday data file for symbol CL.20150600.CME_NY for the date range from 2015-04-20 to 0. | 2015-05-07 05:32:38 Checking Daily data file for symbol CLM15 for the date range from 2015-04-20 to 2015-05-07. | 2015-05-07 05:32:38 Skipping Daily data download for symbol CLM15 since download was already done in last 24 hours. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4 | Symbols used for continuous contract chart: | 2015-05-07 05:32:38 CL.20140700.CME_NY | 2015-05-07 05:32:38 CL.20140800.CME_NY | 2015-05-07 05:32:38 CL.20140900.CME_NY | 2015-05-07 05:32:38 CL.20141000.CME_NY | 2015-05-07 05:32:38 CL.20141100.CME_NY | 2015-05-07 05:32:38 CL.20141200.CME_NY | 2015-05-07 05:32:38 CL.20150100.CME_NY | 2015-05-07 05:32:38 CL.20150200.CME_NY | 2015-05-07 05:32:38 CL.20150300.CME_NY | 2015-05-07 05:32:38 CL.20150400.CME_NY | 2015-05-07 05:32:38 CL.20150500.CME_NY | 2015-05-07 05:32:38 CL.20150600.CME_NY | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Checking for volume based rollover dates. | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2015-05-07 05:32:38 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140700.CME_NY Open price on 2014-06-18 is 106.6. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140800.CME_NY Open price on 2014-06-18 is 106.06. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -0.54000002. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140800.CME_NY Open price on 2014-07-18 is 103.72. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140900.CME_NY Open price on 2014-07-18 is 102.77. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -0.94999999. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140900.CME_NY Open price on 2014-08-18 is 97.1. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141000.CME_NY Open price on 2014-08-18 is 95.14. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -1.96. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141000.CME_NY Open price on 2014-09-19 is 92.97. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141100.CME_NY Open price on 2014-09-19 is 91.96. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -1.01. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141100.CME_NY Open price on 2014-10-17 is 83.18. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141200.CME_NY Open price on 2014-10-17 is 82.4. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -0.77999997. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141200.CME_NY Open price on 2014-11-18 is 75.49. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150100.CME_NY Open price on 2014-11-18 is 75.54. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 0.050000001. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150100.CME_NY Open price on 2014-12-18 is 55.83. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150200.CME_NY Open price on 2014-12-18 is 56.17. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 0.34. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150200.CME_NY Open price on 2015-01-16 is 46.35. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150300.CME_NY Open price on 2015-01-16 is 46.73. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 0.38. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150300.CME_NY Open price on 2015-02-18 is 53.24. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150400.CME_NY Open price on 2015-02-18 is 54.05. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 0.81. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150400.CME_NY Open price on 2015-03-18 is 42.51. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150500.CME_NY Open price on 2015-03-18 is 44.5. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 1.99. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150500.CME_NY Open price on 2015-04-17 is 56.56. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150600.CME_NY Open price on 2015-04-17 is 57.97. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 1.41. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20140700.CME_NY is -25.999941. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20140800.CME_NY is 28.000057. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20140900.CME_NY is 122.99999. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20141000.CME_NY is 319. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20141100.CME_NY is 420. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20141200.CME_NY is 498. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20150100.CME_NY is 493. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20150200.CME_NY is 459.00003. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20150300.CME_NY is 421. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20150400.CME_NY is 340.00003. | 2015-05-07 05:32:39 CL.20150600.CME_NY [CBV] 30 Min #4: Back adjust amount for symbol CL.20150500.CME_NY is 141. | 2015-05-07 05:32:39 Date rule based rollover from CL.20140700.CME_NY to next contract occurs at 2014-06-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20140800.CME_NY to next contract occurs at 2014-07-21. | 2015-05-07 05:32:40 Date rule based rollover from CL.20140900.CME_NY to next contract occurs at 2014-08-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20141000.CME_NY to next contract occurs at 2014-09-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20141100.CME_NY to next contract occurs at 2014-10-20. | 2015-05-07 05:32:40 Date rule based rollover from CL.20141200.CME_NY to next contract occurs at 2014-11-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150100.CME_NY to next contract occurs at 2014-12-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150200.CME_NY to next contract occurs at 2015-01-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150300.CME_NY to next contract occurs at 2015-02-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150400.CME_NY to next contract occurs at 2015-03-19. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150500.CME_NY to next contract occurs at 2015-04-20. | 2015-05-07 05:32:40 Date rule based rollover from CL.20150600.CME_NY to next contract occurs at 2015-05-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20140700.CME_NY for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20140800.CME_NY for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20140900.CME_NY for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20141000.CME_NY for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20141100.CME_NY for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-20. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20141200.CME_NY for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLZ14 for the date range from 2014-10-20 to 2014-11-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20150100.CME_NY for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLF15 for the date range from 2014-11-19 to 2014-12-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20150200.CME_NY for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLG15 for the date range from 2014-12-19 to 2015-01-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20150300.CME_NY for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLH15 for the date range from 2015-01-19 to 2015-02-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20150400.CME_NY for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:40 Checking Daily data file for symbol CLJ15 for the date range from 2015-02-19 to 2015-03-19. | 2015-05-07 05:32:40 Checking Intraday data file for symbol CL.20150500.CME_NY for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:41 Checking Daily data file for symbol CLK15 for the date range from 2015-03-19 to 2015-04-20. | 2015-05-07 05:32:41 Checking Intraday data file for symbol CL.20150600.CME_NY for the date range from 2015-04-20 to 0. | 2015-05-07 05:32:41 Checking Daily data file for symbol CLM15 for the date range from 2015-04-20 to 2015-05-07. | 2015-05-07 05:32:41 Skipping Daily data download for symbol CLM15 since download was already done in last 24 hours. | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10 | Symbols used for continuous contract chart: | 2015-05-07 05:32:41 CL.20140700.CME_NY | 2015-05-07 05:32:41 CL.20140800.CME_NY | 2015-05-07 05:32:41 CL.20140900.CME_NY | 2015-05-07 05:32:41 CL.20141000.CME_NY | 2015-05-07 05:32:41 CL.20141100.CME_NY | 2015-05-07 05:32:41 CL.20141200.CME_NY | 2015-05-07 05:32:41 CL.20150100.CME_NY | 2015-05-07 05:32:41 CL.20150200.CME_NY | 2015-05-07 05:32:41 CL.20150300.CME_NY | 2015-05-07 05:32:41 CL.20150400.CME_NY | 2015-05-07 05:32:41 CL.20150500.CME_NY | 2015-05-07 05:32:41 CL.20150600.CME_NY | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Checking for volume based rollover dates. | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20140700.CME_NY to CL.20140800.CME_NY occurs at 2014-06-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20140800.CME_NY to CL.20140900.CME_NY occurs at 2014-07-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20140900.CME_NY to CL.20141000.CME_NY occurs at 2014-08-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20141000.CME_NY to CL.20141100.CME_NY occurs at 2014-09-19 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20141100.CME_NY to CL.20141200.CME_NY occurs at 2014-10-17 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2015-05-07 05:32:41 CL.20150600.CME_NY [CBV] 240 Min #10: Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140700.CME_NY Open price on 2014-06-18 is 106.6. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140800.CME_NY Open price on 2014-06-18 is 106.06. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140700.CME_NY price difference to CL.20140800.CME_NY is -0.54000002. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140800.CME_NY Open price on 2014-07-18 is 103.72. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140900.CME_NY Open price on 2014-07-18 is 102.77. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140800.CME_NY price difference to CL.20140900.CME_NY is -0.94999999. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140900.CME_NY Open price on 2014-08-18 is 97.1. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141000.CME_NY Open price on 2014-08-18 is 95.14. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20140900.CME_NY price difference to CL.20141000.CME_NY is -1.96. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141000.CME_NY Open price on 2014-09-19 is 92.97. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141100.CME_NY Open price on 2014-09-19 is 91.96. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141000.CME_NY price difference to CL.20141100.CME_NY is -1.01. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141100.CME_NY Open price on 2014-10-17 is 83.18. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141200.CME_NY Open price on 2014-10-17 is 82.4. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141100.CME_NY price difference to CL.20141200.CME_NY is -0.77999997. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141200.CME_NY Open price on 2014-11-18 is 75.49. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150100.CME_NY Open price on 2014-11-18 is 75.54. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 0.050000001. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150100.CME_NY Open price on 2014-12-18 is 55.83. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150200.CME_NY Open price on 2014-12-18 is 56.17. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 0.34. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150200.CME_NY Open price on 2015-01-16 is 46.35. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150300.CME_NY Open price on 2015-01-16 is 46.73. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 0.38. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150300.CME_NY Open price on 2015-02-18 is 53.24. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150400.CME_NY Open price on 2015-02-18 is 54.05. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 0.81. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150400.CME_NY Open price on 2015-03-18 is 42.51. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150500.CME_NY Open price on 2015-03-18 is 44.5. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 1.99. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150500.CME_NY Open price on 2015-04-17 is 56.56. | 2015-05-07 05:32:42 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150600.CME_NY Open price on 2015-04-17 is 57.97. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 1.41. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20140700.CME_NY is -25.999941. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20140800.CME_NY is 28.000057. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20140900.CME_NY is 122.99999. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20141000.CME_NY is 319. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20141100.CME_NY is 420. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20141200.CME_NY is 498. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20150100.CME_NY is 493. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20150200.CME_NY is 459.00003. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20150300.CME_NY is 421. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20150400.CME_NY is 340.00003. | 2015-05-07 05:32:43 CL.20150600.CME_NY [CBV] 240 Min #10: Back adjust amount for symbol CL.20150500.CME_NY is 141. | 2015-05-07 05:32:43 HD Request # 2 | Downloading Historical Daily chart data for ESM15. Starting date: 2015-05-05. Service: cts | 2015-05-07 05:32:43 Historical data download counter reset. | 2015-05-07 05:32:43 HD Request # 2 | Requesting historical Daily data for ESM15 starting at 2015-05-04 | 2015-05-07 05:32:43 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-07 05:32:43 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-07 05:32:43 HTTP request #1 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-07 05:33:40 HD Request # 2 | Download from the SC Historical Data service failed due to a HTTP error. | 2015-05-07 05:33:40 * HD Request # 2 | Error downloading historical Daily data for ESM15. There was a communication error with the server. | 2015-05-07 05:33:40 * HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM15 | 2015-05-07 05:33:40 HD Request # 2 | Daily download COMPLETE for ESM15. Completion time: 57s. Unique request ID: 1 | 2015-05-07 05:33:40 Removed historical data download ID 1 | 2015-05-07 05:33:40 HD Request # 3 | Downloading Historical Daily chart data for NQM15. Starting date: 2015-05-05. Service: cts | 2015-05-07 05:33:40 HD Request # 3 | Requesting historical Daily data for NQM15 starting at 2015-05-04 | 2015-05-07 05:33:40 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-07 05:33:41 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-07 05:33:41 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-07 05:33:41 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-07 05:33:41 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-07 05:33:41 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-07 05:33:41 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-07 05:33:41 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-07 05:33:41 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-07 05:33:41 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-07 05:33:41 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-07 05:33:41 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-07 05:33:41 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:33:41 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:33:41 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1 | Symbols used for continuous contract chart: | 2015-05-07 05:33:41 ESM12 | 2015-05-07 05:33:41 ESU12 | 2015-05-07 05:33:41 ESZ12 | 2015-05-07 05:33:41 ESH13 | 2015-05-07 05:33:41 ESM13 | 2015-05-07 05:33:41 ESU13 | 2015-05-07 05:33:41 ESZ13 | 2015-05-07 05:33:41 ESH14 | 2015-05-07 05:33:41 ESM14 | 2015-05-07 05:33:41 ESU14 | 2015-05-07 05:33:41 ESZ14 | 2015-05-07 05:33:41 ESH15 | 2015-05-07 05:33:41 ESM15 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Checking for volume based rollover dates. | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-13 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-12 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESZ14 to ESH15 occurs at 2014-12-11 | 2015-05-07 05:33:41 ESM15/F.US.EPM15 [CV] Daily #1: Volume based rollover from ESH15 to ESM15 occurs at 2015-03-12 | 2015-05-07 05:33:41 Intraday data recording state for symbol ES.20150300.CME_Eq is set to download pending. | 2015-05-07 05:33:41 HD Request # 4 | Downloading Intraday chart data for ES.20150300.CME_Eq to the file ES.20150300.CME_Eq.scid. Service: cme | 2015-05-07 05:33:41 HD Request # 4 | Download start Date-Time: 2015-03-20 08:29:59.0 | 2015-05-07 05:33:41 HD Request # 4 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:33:41 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:33:41 ES.20150600.CME_Eq [CBV] 15 Min #1: Download is complete for all contract months in chart. Proceeding with data load. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Checking for volume based rollover dates. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Volume based rollover from ES.20140900.CME_Eq to ES.20141200.CME_Eq occurs at 2014-09-12 | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Volume based rollover from ES.20141200.CME_Eq to ES.20150300.CME_Eq occurs at 2014-12-11 | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Volume based rollover from ES.20150300.CME_Eq to ES.20150600.CME_Eq occurs at 2015-03-12 | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20140900.CME_Eq Open price on 2014-09-12 is 1999.25. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20141200.CME_Eq Open price on 2014-09-12 is 1991.25. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20140900.CME_Eq price difference to ES.20141200.CME_Eq is -8. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20141200.CME_Eq Open price on 2014-12-11 is 2026.25. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20150300.CME_Eq Open price on 2014-12-11 is 2019.75. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20141200.CME_Eq price difference to ES.20150300.CME_Eq is -6.5. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20150300.CME_Eq Open price on 2015-03-12 is 2042. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20150600.CME_Eq Open price on 2015-03-12 is 2034.75. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: ES.20150300.CME_Eq price difference to ES.20150600.CME_Eq is -7.25. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Back adjust amount for symbol ES.20140900.CME_Eq is -2175. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Back adjust amount for symbol ES.20141200.CME_Eq is -1375. | 2015-05-07 05:33:42 ES.20150600.CME_Eq [CBV] 15 Min #1: Back adjust amount for symbol ES.20150300.CME_Eq is -725. | 2015-05-07 05:33:42 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-07 05:33:42 CTS FIX - Firm: PTP | 2015-05-07 05:33:42 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2015-05-07 05:33:42 CTS FIX socket (3) | Connected. | 2015-05-07 05:33:42 CTS FIX socket (3) | Starting SSL connection. | 2015-05-07 05:33:42 CTS FIX socket (3) | SSL connection established. | 2015-05-07 05:33:44 CTS FIX: Sending the Logon message. | 2015-05-07 05:33:45 CTS FIX: Connected to data and trade server. FIX version: 4.3.31.0 | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: WYNN. ID: 1 | 2015-05-07 05:33:46 Symbol Error - WYNN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol WYNN is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: LNKD. ID: 2 | 2015-05-07 05:33:46 Symbol Error - LNKD is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol LNKD is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: NFLX. ID: 3 | 2015-05-07 05:33:46 Symbol Error - NFLX is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol NFLX is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: TSLA. ID: 4 | 2015-05-07 05:33:46 Symbol Error - TSLA is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol TSLA is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: TWTR. ID: 5 | 2015-05-07 05:33:46 Symbol Error - TWTR is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol TWTR is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: AMZN. ID: 6 | 2015-05-07 05:33:46 Symbol Error - AMZN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol AMZN is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: FB. ID: 7 | 2015-05-07 05:33:46 Symbol Error - FB is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol FB is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: PCLN. ID: 8 | 2015-05-07 05:33:46 Symbol Error - PCLN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol PCLN is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: AAPL. ID: 9 | 2015-05-07 05:33:46 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: GOOG. ID: 10 | 2015-05-07 05:33:46 Symbol Error - GOOG is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol GOOG is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: BIDU. ID: 11 | 2015-05-07 05:33:46 Symbol Error - BIDU is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 Intraday data recording state for symbol BIDU is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: ES-201312-GLOBEX. ID: 12 | 2015-05-07 05:33:46 Symbol Error - ES-201312-GLOBEX is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:33:46 CTS FIX: Received Account List collateral report. | 2015-05-07 05:33:46 CTS FIX: Subscribing to account: 60* | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: ES.20150600.CME_Eq. ID: 13 | 2015-05-07 05:33:46 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-07 05:33:46 Supported exchange: CME_CO (SIM:COMEX Futures) | 2015-05-07 05:33:46 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2015-05-07 05:33:46 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2015-05-07 05:33:46 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2015-05-07 05:33:46 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2015-05-07 05:33:46 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2015-05-07 05:33:46 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2015-05-07 05:33:46 Supported exchange: CME_KOp (SIM:KCBT Options) | 2015-05-07 05:33:46 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2015-05-07 05:33:46 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2015-05-07 05:33:46 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2015-05-07 05:33:46 Supported exchange: CME_K (SIM:KCBT Futures) | 2015-05-07 05:33:46 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2015-05-07 05:33:46 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2015-05-07 05:33:46 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2015-05-07 05:33:46 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2015-05-07 05:33:46 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2015-05-07 05:33:46 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2015-05-07 05:33:46 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2015-05-07 05:33:46 Supported exchange: CME_COOp (SIM:COMEX Options) | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: CL.20150600.CME_NY. ID: 14 | 2015-05-07 05:33:46 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: ES.20150300.CME_Eq. ID: 15 | 2015-05-07 05:33:46 Historical data request is discarded because it is not for earlier data. | 2015-05-07 05:33:46 Intraday data recording state for symbol ES.20150300.CME_Eq has been reset to downloading. | 2015-05-07 05:33:46 CTS T4 FIX | Starting real-time market data updates for: F.US.EPM15. ID: 16 | 2015-05-07 05:33:46 Symbol Error - F.US.EPM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-07 05:33:46 CTS T4 FIX | Sending security definition request for symbol CL.20150600.CME_NY | 2015-05-07 05:33:46 CTS T4 FIX | Received matching security definition for symbol CL.20150600.CME_NY. Subscribing to data. | 2015-05-07 05:33:46 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2015-05-07 05:33:46 CTS T4 FIX | Sending security definition request for symbol ES.20150300.CME_Eq | 2015-05-07 05:33:48 Symbol Error - ES.20150300.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-07 05:33:48 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-07 05:33:48 CTS FIX: Received Account Update collateral report. | 2015-05-07 05:33:49 CTS T4 FIX | Sending security definition request for symbol ES.20150600.CME_Eq | 2015-05-07 05:33:49 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Subscribing to data. | 2015-05-07 05:33:49 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-05-07 05:33:49 Requesting market depth updates for: CL.20150600.CME_NY if supported. | 2015-05-07 05:33:52 Requesting market depth updates for: ES.20150600.CME_Eq if supported. | 2015-05-07 05:33:52 CTS FIX: Requesting Open Orders for account: 60* | 2015-05-07 05:33:52 CTS FIX: Received Account List collateral report. | 2015-05-07 05:33:53 CTS FIX: Received Account List collateral report. | 2015-05-07 05:34:01 Socket (2) | Shutdown and closed. | 2015-05-07 05:34:01 HD Request # 4 | Error downloading historical Intraday data for ES.20150300.CME_Eq. The network socket has been closed. Retrying download. | 2015-05-07 05:34:01 * HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150300.CME_Eq | 2015-05-07 05:34:01 HD Request # 5 | Downloading Intraday chart data for ES.20150300.CME_Eq to the file ES.20150300.CME_Eq.scid. Service: cme | 2015-05-07 05:34:01 HD Request # 5 | Download start Date-Time: 2015-03-20 08:29:59.0 | 2015-05-07 05:34:01 HD Request # 5 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:34:01 HTTP request #2 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-07 05:34:02 HD Request # 3 | Download from the SC Historical Data service failed due to a HTTP error. | 2015-05-07 05:34:02 * HD Request # 3 | Error downloading historical Daily data for NQM15. There was a communication error with the server. | 2015-05-07 05:34:02 * Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:34:02 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQM15 | 2015-05-07 05:34:02 HD Request # 3 | Daily download COMPLETE for NQM15. Completion time: 22s. Unique request ID: 2 | 2015-05-07 05:34:02 Removed historical data download ID 2 | 2015-05-07 05:34:02 HD Request # 6 | Downloading Historical Daily chart data for GCM15. Starting date: 2015-05-05. Service: cts | 2015-05-07 05:34:02 HD Request # 6 | Requesting historical Daily data for GCM15 starting at 2015-05-04 | 2015-05-07 05:34:02 Date rule based rollover from NQM12 to next contract occurs at 2012-06-07. | 2015-05-07 05:34:02 Date rule based rollover from NQU12 to next contract occurs at 2012-09-13. | 2015-05-07 05:34:02 Date rule based rollover from NQZ12 to next contract occurs at 2012-12-13. | 2015-05-07 05:34:02 Date rule based rollover from NQH13 to next contract occurs at 2013-03-07. | 2015-05-07 05:34:02 Date rule based rollover from NQM13 to next contract occurs at 2013-06-13. | 2015-05-07 05:34:02 Date rule based rollover from NQU13 to next contract occurs at 2013-09-12. | 2015-05-07 05:34:02 Date rule based rollover from NQZ13 to next contract occurs at 2013-12-12. | 2015-05-07 05:34:02 Date rule based rollover from NQH14 to next contract occurs at 2014-03-13. | 2015-05-07 05:34:02 Date rule based rollover from NQM14 to next contract occurs at 2014-06-12. | 2015-05-07 05:34:02 Date rule based rollover from NQU14 to next contract occurs at 2014-09-11. | 2015-05-07 05:34:02 Date rule based rollover from NQZ14 to next contract occurs at 2014-12-11. | 2015-05-07 05:34:02 Date rule based rollover from NQH15 to next contract occurs at 2015-03-12. | 2015-05-07 05:34:02 Date rule based rollover from NQM15 to next contract occurs at 2015-06-11. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-07 05:34:02 Checking Daily data file for symbol NQM15 for the date range from 2015-03-12 to 2015-05-07. | 2015-05-07 05:34:02 Skipping Daily data download for symbol NQM15 since download was already done in last 24 hours. | 2015-05-07 05:34:02 NQM15/F.US.ENQM15 [C] Daily #2 | Symbols used for continuous contract chart: | 2015-05-07 05:34:02 NQM12 | 2015-05-07 05:34:02 NQU12 | 2015-05-07 05:34:02 NQZ12 | 2015-05-07 05:34:02 NQH13 | 2015-05-07 05:34:02 NQM13 | 2015-05-07 05:34:02 NQU13 | 2015-05-07 05:34:02 NQZ13 | 2015-05-07 05:34:02 NQH14 | 2015-05-07 05:34:02 NQM14 | 2015-05-07 05:34:02 NQU14 | 2015-05-07 05:34:02 NQZ14 | 2015-05-07 05:34:02 NQH15 | 2015-05-07 05:34:02 NQM15 | 2015-05-07 05:34:02 CTS T4 FIX | Starting real-time market data updates for: F.US.ENQM15. ID: 18 | 2015-05-07 05:34:03 Symbol Error - F.US.ENQM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-07 05:34:03 Socket (4) | Shutdown and closed. | 2015-05-07 05:34:21 HD Request # 5 | Error downloading historical Intraday data for ES.20150300.CME_Eq. The network socket has been closed. Retrying download. | 2015-05-07 05:34:22 * HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150300.CME_Eq | 2015-05-07 05:34:22 HD Request # 7 | Downloading Intraday chart data for ES.20150300.CME_Eq to the file ES.20150300.CME_Eq.scid. Service: cme | 2015-05-07 05:34:22 HD Request # 7 | Download start Date-Time: 2015-03-20 08:29:59.0 | 2015-05-07 05:34:22 HD Request # 7 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:34:22 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:34:22 HTTP request #3 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-07 05:34:23 HD Request # 6 | Download from the SC Historical Data service failed due to a HTTP error. | 2015-05-07 05:34:23 * HD Request # 6 | Error downloading historical Daily data for GCM15. There was a communication error with the server. | 2015-05-07 05:34:23 * HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCM15 | 2015-05-07 05:34:23 HD Request # 6 | Daily download COMPLETE for GCM15. Completion time: 21s. Unique request ID: 3 | 2015-05-07 05:34:23 Removed historical data download ID 3 | 2015-05-07 05:34:23 HD Request # 8 | Downloading Historical Daily chart data for CLM15. Starting date: 2015-05-05. Service: cts | 2015-05-07 05:34:23 HD Request # 8 | Requesting historical Daily data for CLM15 starting at 2015-05-04 | 2015-05-07 05:34:23 GC.20150600.CME_CO [CBV] 5 Min #1: Download is complete for all contract months in chart. Proceeding with data load. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Checking for volume based rollover dates. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Volume based rollover from GC.20140800.CME_CO to GC.20141200.CME_CO occurs at 2014-07-30 | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Volume based rollover from GC.20141200.CME_CO to GC.20150200.CME_CO occurs at 2014-11-26 | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Volume based rollover from GC.20150200.CME_CO to GC.20150400.CME_CO occurs at 2015-01-29 | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Volume based rollover from GC.20150400.CME_CO to GC.20150600.CME_CO occurs at 2015-03-30 | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20140800.CME_CO Open price on 2014-07-30 is 1298.6. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20141200.CME_CO Open price on 2014-07-30 is 1300.5. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20140800.CME_CO price difference to GC.20141200.CME_CO is 1.9. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20141200.CME_CO Open price on 2014-11-26 is 1200.5. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150200.CME_CO Open price on 2014-11-26 is 1201.6. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20141200.CME_CO price difference to GC.20150200.CME_CO is 1.1. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150200.CME_CO Open price on 2015-01-29 is 1283.3. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150400.CME_CO Open price on 2015-01-29 is 1284. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150200.CME_CO price difference to GC.20150400.CME_CO is 0.69999999. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150400.CME_CO Open price on 2015-03-30 is 1198. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150600.CME_CO Open price on 2015-03-30 is 1198.6. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: GC.20150400.CME_CO price difference to GC.20150600.CME_CO is 0.60000002. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Back adjust amount for symbol GC.20140800.CME_CO is 43. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Back adjust amount for symbol GC.20141200.CME_CO is 24. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Back adjust amount for symbol GC.20150200.CME_CO is 12.999999. | 2015-05-07 05:34:25 GC.20150600.CME_CO [CBV] 5 Min #1: Back adjust amount for symbol GC.20150400.CME_CO is 6. | 2015-05-07 05:34:25 CTS T4 FIX | Starting real-time market data updates for: GC.20150600.CME_CO. ID: 20 | 2015-05-07 05:34:25 Intraday data recording state for symbol GC.20150600.CME_CO is set to download pending. | 2015-05-07 05:34:25 CTS T4 FIX | Sending security definition request for symbol GC.20150600.CME_CO | 2015-05-07 05:34:26 CTS T4 FIX | Received matching security definition for symbol GC.20150600.CME_CO. Subscribing to data. | 2015-05-07 05:34:26 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2015-05-07 05:34:26 Socket (5) | Shutdown and closed. | 2015-05-07 05:34:42 HD Request # 7 | Error downloading historical Intraday data for ES.20150300.CME_Eq. The network socket has been closed. Retrying download. | 2015-05-07 05:34:42 * HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES.20150300.CME_Eq | 2015-05-07 05:34:42 HD Request # 7 | Intraday download COMPLETE for ES.20150300.CME_Eq. Completion time: 20s. Unique request ID: 5 | 2015-05-07 05:34:42 Removed historical data download ID 5 | 2015-05-07 05:34:42 Real-time Intraday chart data file updates started for ES.20150300.CME_Eq | 2015-05-07 05:34:42 HD Request # 9 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:34:42 HD Request # 9 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:34:42 HD Request # 9 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:34:42 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:34:42 HTTP request #4 returned the following error: Windows error code 12029: A connection with the server could not be established | 2015-05-07 05:34:47 HD Request # 8 | Download from the SC Historical Data service failed due to a HTTP error. | 2015-05-07 05:34:47 * HD Request # 8 | Error downloading historical Daily data for CLM15. There was a communication error with the server. | 2015-05-07 05:34:47 * HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLM15 | 2015-05-07 05:34:47 HD Request # 8 | Daily download COMPLETE for CLM15. Completion time: 24s. Unique request ID: 4 | 2015-05-07 05:34:47 Removed historical data download ID 4 | 2015-05-07 05:34:47 CL.20150600.CME_NY [CBV] 5 Min #6: Download is complete for all contract months in chart. Proceeding with data load. | 2015-05-07 05:34:47 CL.20150600.CME_NY [CBV] 5 Min #6: Checking for volume based rollover dates. | 2015-05-07 05:34:47 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20141200.CME_NY to CL.20150100.CME_NY occurs at 2014-11-18 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20150100.CME_NY to CL.20150200.CME_NY occurs at 2014-12-18 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20150200.CME_NY to CL.20150300.CME_NY occurs at 2015-01-16 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20150300.CME_NY to CL.20150400.CME_NY occurs at 2015-02-18 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20150400.CME_NY to CL.20150500.CME_NY occurs at 2015-03-18 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Volume based rollover from CL.20150500.CME_NY to CL.20150600.CME_NY occurs at 2015-04-17 | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20141200.CME_NY Open price on 2014-11-18 is 75.49. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150100.CME_NY Open price on 2014-11-18 is 75.54. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20141200.CME_NY price difference to CL.20150100.CME_NY is 0.050000001. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150100.CME_NY Open price on 2014-12-18 is 55.83. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150200.CME_NY Open price on 2014-12-18 is 56.17. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150100.CME_NY price difference to CL.20150200.CME_NY is 0.34. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150200.CME_NY Open price on 2015-01-16 is 46.35. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150300.CME_NY Open price on 2015-01-16 is 46.73. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150200.CME_NY price difference to CL.20150300.CME_NY is 0.38. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150300.CME_NY Open price on 2015-02-18 is 53.24. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150400.CME_NY Open price on 2015-02-18 is 54.05. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150300.CME_NY price difference to CL.20150400.CME_NY is 0.81. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150400.CME_NY Open price on 2015-03-18 is 42.51. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150500.CME_NY Open price on 2015-03-18 is 44.5. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150400.CME_NY price difference to CL.20150500.CME_NY is 1.99. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150500.CME_NY Open price on 2015-04-17 is 56.56. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150600.CME_NY Open price on 2015-04-17 is 57.97. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: CL.20150500.CME_NY price difference to CL.20150600.CME_NY is 1.41. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20141200.CME_NY is 498. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20150100.CME_NY is 493. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20150200.CME_NY is 459.00003. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20150300.CME_NY is 421. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20150400.CME_NY is 340.00003. | 2015-05-07 05:34:48 CL.20150600.CME_NY [CBV] 5 Min #6: Back adjust amount for symbol CL.20150500.CME_NY is 141. | 2015-05-07 05:34:48 Socket (6) | Shutdown and closed. | 2015-05-07 05:35:02 HD Request # 9 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:35:02 * HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:35:02 HD Request # 10 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:35:02 HD Request # 10 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:35:02 HD Request # 10 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:35:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:35:02 Socket (7) | Shutdown and closed. | 2015-05-07 05:35:22 HD Request # 10 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:35:22 * HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:35:22 HD Request # 11 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:35:22 HD Request # 11 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:35:22 HD Request # 11 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:35:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:35:22 Socket (8) | Shutdown and closed. | 2015-05-07 05:35:42 HD Request # 11 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:35:42 * HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:35:42 HD Request # 11 | Intraday download COMPLETE for WYNN. Completion time: 20s. Unique request ID: 6 | 2015-05-07 05:35:42 Removed historical data download ID 6 | 2015-05-07 05:35:42 Real-time Intraday chart data file updates started for WYNN | 2015-05-07 05:35:42 Intraday data recording state for symbol WYNN is set to download pending. | 2015-05-07 05:35:42 HD Request # 12 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: cts | 2015-05-07 05:35:42 HD Request # 12 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:35:42 HD Request # 12 | Error downloading historical Intraday data for WYNN. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:35:42 * HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:35:42 HD Request # 12 | Intraday download COMPLETE for WYNN. Completion time: 0s. Unique request ID: 21 | 2015-05-07 05:35:42 Removed historical data download ID 21 | 2015-05-07 05:35:42 Real-time Intraday chart data file updates started for WYNN | 2015-05-07 05:35:42 HD Request # 13 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:35:42 HD Request # 13 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:35:42 HD Request # 13 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:35:42 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:35:42 Socket (9) | Shutdown and closed. | 2015-05-07 05:36:02 HD Request # 13 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:36:02 * HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:36:02 HD Request # 14 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:36:02 HD Request # 14 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:36:02 HD Request # 14 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:36:02 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:36:02 Socket (10) | Shutdown and closed. | 2015-05-07 05:36:22 HD Request # 14 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:36:22 * HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:36:22 HD Request # 15 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:36:22 HD Request # 15 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:36:22 HD Request # 15 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:36:22 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:36:22 Socket (11) | Shutdown and closed. | 2015-05-07 05:36:42 HD Request # 15 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:36:42 * HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:36:42 HD Request # 15 | Intraday download COMPLETE for LNKD. Completion time: 20s. Unique request ID: 7 | 2015-05-07 05:36:42 Removed historical data download ID 7 | 2015-05-07 05:36:42 Real-time Intraday chart data file updates started for LNKD | 2015-05-07 05:36:42 Intraday data recording state for symbol LNKD is set to download pending. | 2015-05-07 05:36:42 HD Request # 16 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: cts | 2015-05-07 05:36:42 HD Request # 16 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:36:42 HD Request # 16 | Error downloading historical Intraday data for LNKD. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:36:42 * HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:36:42 HD Request # 16 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 22 | 2015-05-07 05:36:42 Removed historical data download ID 22 | 2015-05-07 05:36:42 Real-time Intraday chart data file updates started for LNKD | 2015-05-07 05:36:42 HD Request # 17 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:36:42 HD Request # 17 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:36:42 HD Request # 17 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:36:42 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:36:42 Socket (12) | Shutdown and closed. | 2015-05-07 05:37:02 HD Request # 17 | Error downloading historical Intraday data for NFLX. The network socket has been closed. Retrying download. | 2015-05-07 05:37:02 * HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:37:02 HD Request # 18 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:37:02 HD Request # 18 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:37:02 HD Request # 18 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:37:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:37:02 Socket (13) | Shutdown and closed. | 2015-05-07 05:37:22 HD Request # 18 | Error downloading historical Intraday data for NFLX. The network socket has been closed. Retrying download. | 2015-05-07 05:37:22 * HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:37:22 HD Request # 19 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:37:22 HD Request # 19 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:37:22 HD Request # 19 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:37:22 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:37:22 Socket (14) | Shutdown and closed. | 2015-05-07 05:37:42 HD Request # 19 | Error downloading historical Intraday data for NFLX. The network socket has been closed. Retrying download. | 2015-05-07 05:37:42 * HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:37:42 HD Request # 19 | Intraday download COMPLETE for NFLX. Completion time: 20s. Unique request ID: 8 | 2015-05-07 05:37:42 Removed historical data download ID 8 | 2015-05-07 05:37:42 Real-time Intraday chart data file updates started for NFLX | 2015-05-07 05:37:42 Intraday data recording state for symbol NFLX is set to download pending. | 2015-05-07 05:37:42 HD Request # 20 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: cts | 2015-05-07 05:37:42 HD Request # 20 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:37:42 HD Request # 20 | Error downloading historical Intraday data for NFLX. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:37:42 * HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:37:42 HD Request # 20 | Intraday download COMPLETE for NFLX. Completion time: 0s. Unique request ID: 23 | 2015-05-07 05:37:42 Removed historical data download ID 23 | 2015-05-07 05:37:42 Real-time Intraday chart data file updates started for NFLX | 2015-05-07 05:37:42 HD Request # 21 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2015-05-07 05:37:42 HD Request # 21 | Download start Date-Time: 2015-05-06 15:43:08.0 | 2015-05-07 05:37:42 HD Request # 21 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:37:42 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:37:42 Socket (15) | Shutdown and closed. | 2015-05-07 05:38:02 HD Request # 21 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2015-05-07 05:38:02 * HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TSLA | 2015-05-07 05:38:02 HD Request # 22 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2015-05-07 05:38:02 HD Request # 22 | Download start Date-Time: 2015-05-06 15:43:08.0 | 2015-05-07 05:38:02 HD Request # 22 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:38:02 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:38:02 Socket (16) | Shutdown and closed. | 2015-05-07 05:38:22 HD Request # 22 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2015-05-07 05:38:22 * HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TSLA | 2015-05-07 05:38:22 HD Request # 23 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2015-05-07 05:38:22 HD Request # 23 | Download start Date-Time: 2015-05-06 15:43:08.0 | 2015-05-07 05:38:22 HD Request # 23 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:38:22 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:38:22 Socket (17) | Shutdown and closed. | 2015-05-07 05:38:42 HD Request # 23 | Error downloading historical Intraday data for TSLA. The network socket has been closed. Retrying download. | 2015-05-07 05:38:42 * HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TSLA | 2015-05-07 05:38:42 HD Request # 23 | Intraday download COMPLETE for TSLA. Completion time: 20s. Unique request ID: 9 | 2015-05-07 05:38:42 Removed historical data download ID 9 | 2015-05-07 05:38:42 Real-time Intraday chart data file updates started for TSLA | 2015-05-07 05:38:42 Intraday data recording state for symbol TSLA is set to download pending. | 2015-05-07 05:38:42 HD Request # 24 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: cts | 2015-05-07 05:38:42 HD Request # 24 | Download start Date-Time: 2015-05-06 15:43:08.0 | 2015-05-07 05:38:42 HD Request # 24 | Error downloading historical Intraday data for TSLA. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:38:42 * HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TSLA | 2015-05-07 05:38:42 HD Request # 24 | Intraday download COMPLETE for TSLA. Completion time: 0s. Unique request ID: 24 | 2015-05-07 05:38:42 Removed historical data download ID 24 | 2015-05-07 05:38:42 Real-time Intraday chart data file updates started for TSLA | 2015-05-07 05:38:42 HD Request # 25 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: equities.us | 2015-05-07 05:38:42 HD Request # 25 | Download start Date-Time: 2015-05-06 15:42:31.0 | 2015-05-07 05:38:42 HD Request # 25 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:38:42 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:38:42 Socket (18) | Shutdown and closed. | 2015-05-07 05:39:02 HD Request # 25 | Error downloading historical Intraday data for TWTR. The network socket has been closed. Retrying download. | 2015-05-07 05:39:02 * HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TWTR | 2015-05-07 05:39:02 HD Request # 26 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: equities.us | 2015-05-07 05:39:02 HD Request # 26 | Download start Date-Time: 2015-05-06 15:42:31.0 | 2015-05-07 05:39:02 HD Request # 26 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:39:02 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:39:02 File >> Disconnect selected. | 2015-05-07 05:39:11 Removed historical data download ID 11 | 2015-05-07 05:39:11 Removed historical data download ID 12 | 2015-05-07 05:39:11 Removed historical data download ID 13 | 2015-05-07 05:39:11 Removed historical data download ID 14 | 2015-05-07 05:39:11 Removed historical data download ID 15 | 2015-05-07 05:39:11 Removed historical data download ID 16 | 2015-05-07 05:39:11 Removed historical data download ID 17 | 2015-05-07 05:39:11 Removed historical data download ID 18 | 2015-05-07 05:39:11 Removed historical data download ID 20 | 2015-05-07 05:39:11 HD Request # 26 | Download canceled. | 2015-05-07 05:39:11 Socket (19) | Shutdown and closed. | 2015-05-07 05:39:11 HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TWTR | 2015-05-07 05:39:11 HD Request # 26 | Intraday download COMPLETE for TWTR. Completion time: 9s. Unique request ID: 10 | 2015-05-07 05:39:11 Removed historical data download ID 10 | 2015-05-07 05:39:11 Intraday data recording state for symbol TWTR is set to download pending. | 2015-05-07 05:39:11 CTS FIX: DisconnectFIX called. | 2015-05-07 05:39:11 CTS FIX: Sending a Logout message. | 2015-05-07 05:39:11 CTS FIX Historical Data: DisconnectFIX called. | 2015-05-07 05:39:11 CTS FIX: Disconnected. | 2015-05-07 05:39:11 CTS FIX: Received a Logout message. Text = Successful logout upon request | 2015-05-07 05:39:11 CTS FIX socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-05-07 05:39:11 CTS FIX socket (3) | SSL has been shut down. | 2015-05-07 05:39:11 CTS FIX socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-05-07 05:39:11 CTS FIX socket (3) | Shutdown and closed. | 2015-05-07 05:39:11 CTS FIX: Logged out and disconnected. | 2015-05-07 05:39:11 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2015-05-07 05:39:22 CTS FIX - Firm: PTP | 2015-05-07 05:39:22 CTS FIX socket (0) | Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2015-05-07 05:39:22 CTS FIX socket (20) | Connected. | 2015-05-07 05:39:22 CTS FIX socket (20) | Starting SSL connection. | 2015-05-07 05:39:22 CTS FIX socket (20) | SSL connection established. | 2015-05-07 05:39:22 CTS FIX: Sending the Logon message. | 2015-05-07 05:39:22 CTS FIX: Connected to data and trade server. FIX version: 4.3.31.0 | 2015-05-07 05:39:22 CTS T4 FIX | Starting real-time market data updates for: WYNN. ID: 1 | 2015-05-07 05:39:23 Symbol Error - WYNN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol WYNN is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: LNKD. ID: 2 | 2015-05-07 05:39:23 Symbol Error - LNKD is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol LNKD is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: NFLX. ID: 3 | 2015-05-07 05:39:23 Symbol Error - NFLX is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol NFLX is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: TSLA. ID: 4 | 2015-05-07 05:39:23 Symbol Error - TSLA is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol TSLA is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: TWTR. ID: 5 | 2015-05-07 05:39:23 Symbol Error - TWTR is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol TWTR is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: AMZN. ID: 6 | 2015-05-07 05:39:23 Symbol Error - AMZN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol AMZN is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: FB. ID: 7 | 2015-05-07 05:39:23 Symbol Error - FB is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol FB is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: PCLN. ID: 8 | 2015-05-07 05:39:23 Symbol Error - PCLN is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol PCLN is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: AAPL. ID: 9 | 2015-05-07 05:39:23 Symbol Error - AAPL is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol AAPL is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: GOOG. ID: 10 | 2015-05-07 05:39:23 Symbol Error - GOOG is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol GOOG is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: BIDU. ID: 11 | 2015-05-07 05:39:23 Symbol Error - BIDU is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 Intraday data recording state for symbol BIDU is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: ES-201312-GLOBEX. ID: 12 | 2015-05-07 05:39:23 Symbol Error - ES-201312-GLOBEX is unknown, unavailable, or improperly formatted. CTS T4 FIX | Symbol format needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 HD Request # 27 | Downloading Intraday chart data for TWTR to the file TWTR.scid. Service: cts | 2015-05-07 05:39:23 HD Request # 27 | Download start Date-Time: 2015-05-06 15:42:31.0 | 2015-05-07 05:39:23 HD Request # 27 | Error downloading historical Intraday data for TWTR. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:39:23 * HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TWTR | 2015-05-07 05:39:23 HD Request # 27 | Intraday download COMPLETE for TWTR. Completion time: 0s. Unique request ID: 25 | 2015-05-07 05:39:23 Removed historical data download ID 25 | 2015-05-07 05:39:23 Real-time Intraday chart data file updates started for TWTR | 2015-05-07 05:39:23 HD Request # 28 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:39:23 HD Request # 28 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:39:23 HD Request # 28 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:39:23 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: ES.20150600.CME_Eq. ID: 13 | 2015-05-07 05:39:23 Intraday data recording state for symbol ES.20150600.CME_Eq is set to download pending. | 2015-05-07 05:39:23 CTS FIX: Received Account List collateral report. | 2015-05-07 05:39:23 CTS FIX: Subscribing to account: 60* | 2015-05-07 05:39:23 Supported exchange: CME_CO (SIM:COMEX Futures) | 2015-05-07 05:39:23 Supported exchange: CME_EqOp (SIM:CME Equity Options) | 2015-05-07 05:39:23 Supported exchange: CME_NYOp (SIM:NYMEX Options) | 2015-05-07 05:39:23 Supported exchange: CME_AgOp (SIM:CME Agricultural Options) | 2015-05-07 05:39:23 Supported exchange: CME_Eq (SIM:CME Equity Futures) | 2015-05-07 05:39:23 Supported exchange: CME_In (SIM:CME Interest Rate Futures) | 2015-05-07 05:39:23 Supported exchange: CME_C (SIM:CBOT Commodity Futures) | 2015-05-07 05:39:23 Supported exchange: CME_KOp (SIM:KCBT Options) | 2015-05-07 05:39:23 Supported exchange: CME_F (SIM:CBOT Financial Futures) | 2015-05-07 05:39:23 Supported exchange: CME_E (SIM:CBOT Equity Futures) | 2015-05-07 05:39:23 Supported exchange: CME_COp (SIM:CBOT Commodity Options) | 2015-05-07 05:39:23 Supported exchange: CME_K (SIM:KCBT Futures) | 2015-05-07 05:39:23 Supported exchange: CME_EOp (SIM:CBOT Equity Options) | 2015-05-07 05:39:23 Supported exchange: CME_NY (SIM:NYMEX Futures) | 2015-05-07 05:39:23 Supported exchange: CME_Fo (SIM:CME Foreign Exchange Futures) | 2015-05-07 05:39:23 Supported exchange: CME_Ag (SIM:CME Agricultural Futures) | 2015-05-07 05:39:23 Supported exchange: CME_FoOp (SIM:CME Foreign Exchange Options) | 2015-05-07 05:39:23 Supported exchange: CME_FOp (SIM:CBOT Financial Options) | 2015-05-07 05:39:23 Supported exchange: CME_InOp (SIM:CME Interest Rate Options) | 2015-05-07 05:39:23 Supported exchange: CME_COOp (SIM:COMEX Options) | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: ES.20150300.CME_Eq. ID: 14 | 2015-05-07 05:39:23 Intraday data recording state for symbol ES.20150300.CME_Eq is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: GC.20150600.CME_CO. ID: 15 | 2015-05-07 05:39:23 Intraday data recording state for symbol GC.20150600.CME_CO is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: CL.20150600.CME_NY. ID: 16 | 2015-05-07 05:39:23 Intraday data recording state for symbol CL.20150600.CME_NY is set to download pending. | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: F.US.EPM15. ID: 17 | 2015-05-07 05:39:23 CTS FIX: Received Account Update collateral report. | 2015-05-07 05:39:23 Symbol Error - F.US.EPM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-07 05:39:23 CTS T4 FIX | Starting real-time market data updates for: F.US.ENQM15. ID: 18 | 2015-05-07 05:39:23 Symbol Error - F.US.ENQM15 is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (3) Exchange is not allowed for User | 2015-05-07 05:39:23 CTS T4 FIX | Sending security definition request for symbol CL.20150600.CME_NY | 2015-05-07 05:39:23 CTS T4 FIX | Received matching security definition for symbol CL.20150600.CME_NY. Subscribing to data. | 2015-05-07 05:39:23 CTS T4 FIX | Received 1 security definitions for underlying symbol CL | 2015-05-07 05:39:23 CTS T4 FIX | Sending security definition request for symbol ES.20150300.CME_Eq | 2015-05-07 05:39:25 Symbol Error - ES.20150300.CME_Eq is unknown, unavailable, or improperly formatted. Security definition not found | 2015-05-07 05:39:25 CTS T4 FIX | Received 0 security definitions for underlying symbol ES | 2015-05-07 05:39:25 CTS T4 FIX | Sending security definition request for symbol ES.20150600.CME_Eq | 2015-05-07 05:39:26 CTS T4 FIX | Received matching security definition for symbol ES.20150600.CME_Eq. Subscribing to data. | 2015-05-07 05:39:27 CTS T4 FIX | Received 1 security definitions for underlying symbol ES | 2015-05-07 05:39:27 CTS FIX: Requesting Open Orders for account: 60* | 2015-05-07 05:39:28 Requesting market depth updates for: CL.20150600.CME_NY if supported. | 2015-05-07 05:39:28 Requesting market depth updates for: ES.20150600.CME_Eq if supported. | 2015-05-07 05:39:28 CTS FIX: Received Account List collateral report. | 2015-05-07 05:39:28 CTS T4 FIX | Sending security definition request for symbol GC.20150600.CME_CO | 2015-05-07 05:39:28 CTS T4 FIX | Received matching security definition for symbol GC.20150600.CME_CO. Subscribing to data. | 2015-05-07 05:39:28 CTS T4 FIX | Received 1 security definitions for underlying symbol GC | 2015-05-07 05:39:28 CTS FIX: Received Account List collateral report. | 2015-05-07 05:39:38 Socket (21) | Shutdown and closed. | 2015-05-07 05:39:43 HD Request # 28 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:39:43 * HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:39:43 HD Request # 29 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:39:43 HD Request # 29 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:39:43 HD Request # 29 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:39:43 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:39:43 Socket (22) | Shutdown and closed. | 2015-05-07 05:40:03 HD Request # 29 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:40:03 * HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:40:03 HD Request # 30 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: equities.us | 2015-05-07 05:40:03 HD Request # 30 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:40:03 HD Request # 30 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:40:03 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:40:03 Socket (23) | Shutdown and closed. | 2015-05-07 05:40:23 HD Request # 30 | Error downloading historical Intraday data for WYNN. The network socket has been closed. Retrying download. | 2015-05-07 05:40:23 * HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:40:23 HD Request # 30 | Intraday download COMPLETE for WYNN. Completion time: 20s. Unique request ID: 26 | 2015-05-07 05:40:23 Removed historical data download ID 26 | 2015-05-07 05:40:23 Real-time Intraday chart data file updates started for WYNN | 2015-05-07 05:40:23 Intraday data recording state for symbol WYNN is set to download pending. | 2015-05-07 05:40:23 HD Request # 31 | Downloading Intraday chart data for WYNN to the file WYNN.scid. Service: cts | 2015-05-07 05:40:23 HD Request # 31 | Download start Date-Time: 2015-05-06 15:38:29.0 | 2015-05-07 05:40:23 HD Request # 31 | Error downloading historical Intraday data for WYNN. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:40:23 * HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for WYNN | 2015-05-07 05:40:23 HD Request # 31 | Intraday download COMPLETE for WYNN. Completion time: 0s. Unique request ID: 41 | 2015-05-07 05:40:23 Removed historical data download ID 41 | 2015-05-07 05:40:23 Real-time Intraday chart data file updates started for WYNN | 2015-05-07 05:40:23 HD Request # 32 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:40:23 HD Request # 32 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:40:23 HD Request # 32 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:40:23 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:40:23 Socket (24) | Shutdown and closed. | 2015-05-07 05:40:43 HD Request # 32 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:40:43 * HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:40:43 HD Request # 33 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:40:43 HD Request # 33 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:40:43 HD Request # 33 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:40:43 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:40:43 Socket (25) | Shutdown and closed. | 2015-05-07 05:41:03 HD Request # 33 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:41:03 * HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:41:03 HD Request # 34 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: equities.us | 2015-05-07 05:41:03 HD Request # 34 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:41:03 HD Request # 34 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:41:03 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:41:03 Socket (26) | Shutdown and closed. | 2015-05-07 05:41:23 HD Request # 34 | Error downloading historical Intraday data for LNKD. The network socket has been closed. Retrying download. | 2015-05-07 05:41:23 * HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:41:23 HD Request # 34 | Intraday download COMPLETE for LNKD. Completion time: 20s. Unique request ID: 27 | 2015-05-07 05:41:23 Removed historical data download ID 27 | 2015-05-07 05:41:23 Real-time Intraday chart data file updates started for LNKD | 2015-05-07 05:41:23 Intraday data recording state for symbol LNKD is set to download pending. | 2015-05-07 05:41:23 HD Request # 35 | Downloading Intraday chart data for LNKD to the file LNKD.scid. Service: cts | 2015-05-07 05:41:23 HD Request # 35 | Download start Date-Time: 2015-05-06 15:33:39.0 | 2015-05-07 05:41:23 HD Request # 35 | Error downloading historical Intraday data for LNKD. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2015-05-07 05:41:23 * HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for LNKD | 2015-05-07 05:41:23 HD Request # 35 | Intraday download COMPLETE for LNKD. Completion time: 0s. Unique request ID: 42 | 2015-05-07 05:41:23 Removed historical data download ID 42 | 2015-05-07 05:41:23 Real-time Intraday chart data file updates started for LNKD | 2015-05-07 05:41:23 HD Request # 36 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:41:23 HD Request # 36 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:41:23 HD Request # 36 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:41:23 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:41:23 Current selected Data/Trading service: CTS T4 FIX | 2015-05-07 05:41:31 Socket (27) | Shutdown and closed. | 2015-05-07 05:41:43 HD Request # 36 | Error downloading historical Intraday data for NFLX. The network socket has been closed. Retrying download. | 2015-05-07 05:41:43 * HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:41:43 HD Request # 37 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:41:43 HD Request # 37 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:41:43 HD Request # 37 | Using server: scdf2.sierracharts.com port 10149 | 2015-05-07 05:41:43 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-05-07 05:41:43 Socket (28) | Shutdown and closed. | 2015-05-07 05:42:03 HD Request # 37 | Error downloading historical Intraday data for NFLX. The network socket has been closed. Retrying download. | 2015-05-07 05:42:03 * HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NFLX | 2015-05-07 05:42:03 HD Request # 38 | Downloading Intraday chart data for NFLX to the file NFLX.scid. Service: equities.us | 2015-05-07 05:42:03 HD Request # 38 | Download start Date-Time: 2015-05-06 15:32:55.0 | 2015-05-07 05:42:03 HD Request # 38 | Using server: scdf1.sierracharts.com port 10149 | 2015-05-07 05:42:03 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-05-07 05:42:03 |
[2015-05-07 10:50:15] |
See: Notice: Sierra Chart Exchange Data Feed Is Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
