Date/Time: Sun, 22 Dec 2024 16:09:36 +0000
Notice: Sierra Chart Exchange Data Feed Is Down
View Count: 1566
[2015-05-07 10:20:27] |
Currently we are experiencing a problem the Sierra Chart Exchange Data Feed. There is a loss of network connectivity and it is being immediately looked into. We will update this thread as we have more information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-07 10:38:21] |
This is from the data center: Problem with our ISP, now clearing.
[2015-05-07 10:48:59] |
If you have your trading service/broker data feed available to you, then to use that: Select Global Settings >>Data/Trade Service Settings. Uncheck Allow Support for Sierra Chart Data Feeds. Select File >> Disconnect. Select File >> Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-07 11:16:58] |
User47068 - Posts: 15 |
Is this issue resolved?
[2015-05-07 11:17:58] |
Ah...never mind I was confused by the time stamp. I see that it's fairly recent. Thanks.
[2015-05-07 11:39:05] |
It is being worked on urgently, we are told.
[2015-05-07 11:41:41] |
moonmist - Posts: 127 |
Seems to work again now.
[2015-05-07 12:27:56] |
Pawel_Szpak - Posts: 48 |
Hi, can you confirm that this is resolved? Also will there be missing data if I delete & download today? |
[2015-05-07 14:30:49] |
Demi1201 - Posts: 68 |
The issue is not resolved as far as I can see. If it is for others and I'm the only one experiencing problems please let me know.
[2015-05-07 15:48:06] |
User40520 - Posts: 62 |
has been fine for me since moonmist posted hours back
[2015-05-07 15:53:19] |
I should have added, I use Barchart datafeed with Ensign and it was down at the same time and restarted at the same time as SC's feed.
[2015-05-07 16:21:12] |
Yes, the issue is resolved. If you still have a problem start a new Support Request.
[2015-05-08 08:47:35] |
There was some missing data for the ICE and EUREX markets but that has been filled in as of this time for the major symbols. If you experience missing data, please let us know. As always, to re-download the missing data, right-click before the missing data in the chart and select Delete Data and Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
