Date/Time: Fri, 22 Nov 2024 19:55:45 +0000
External Alert
View Count: 1697
[2013-06-03 22:08:46]
user87297 - Posts: 6
Hi
How can i use with External Alert kind of "wav" instead the number Alert 1 until Alert 64
I am config in "General seting" to Alert 7 and i try the "TestSound" it is ok. but in active chart
the sound give me the
Alert 1 sound .
Many Thanks
Amos.
imageAlerts.jpg / V - Attached On 2013-06-03 22:06:50 UTC - Size: 54.59 KB - 555 views
imageAdvanced Setting.jpg / V - Attached On 2013-06-03 22:07:03 UTC - Size: 112.45 KB - 517 views
imageGeneral Setting.jpg / V - Attached On 2013-06-03 22:07:17 UTC - Size: 80.32 KB - 571 views
[2013-06-04 00:36:18]
Please refer to the documentation for Alert Settings here:
http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings
We see that you are using a custom study, you have to contact the custom study developer about this. Selecting a particular Alert # from the list of alerts, is not going to affect that.
