Date/Time: Sun, 22 Dec 2024 05:43:21 +0000
[User Discussion] - add candle type : candle price volume bars HOLLOW
View Count: 2484
[2015-05-07 09:43:46]
sierra28 - Posts: 120
hello support,
candle bars hollow is very usefull but i like also candle price volume bar.
So could you mixe them and create :candle price volume bars HOLLOW.
[2015-05-12 11:07:17]
Do you think it is possible ?
thanks
[2015-06-10 18:16:56]
hello support,
could you please add this feature ?
thanks
[2015-06-29 16:25:25]
can you give me an answer ?
[2015-06-30 01:02:14]
SgtJ - Posts: 154
Sierra28, it sounds as if what you're trying to do can already be done. Post a pic if you can.
[2015-06-30 07:24:14]
hi guys,
@40winks "Candle Bar Hollow" and "Candle Price Volume Bars" already exist YES, but i'd like these 2 candle types togethers to see quickly volume total display with the width of the candles and volume echanged(by adding V.B.P studie).
@Sgtj my request is easy to undestand and probably easy to do.
I'm sure that sierra team undestood what i need but i don't undestand why they don't tell me anything. Just need YES or NO for this feature.
Date Time Of Last Edit: 2015-06-30 07:31:02
[2015-06-30 13:47:37]
Sawtooth - Posts: 4141
To achieve hollow candles when using Candle Price Volume Bars, set the CandleStick Up Fill and CandleStick Down Fill to the same color as your chart background.
Global Settings >> Graphics Settings
or
Chart >> Graphics Settings
if you have Use Global Graphics Settings... unchecked.
[2015-06-30 16:35:31]
Thanks tomgilb,
it is a good idea but unfortunately i color the vwap band area so that i have 2 colors for the font of a chart:(chart background and first vwap band area).
i recognize this feature is not very important but i suppose it doesn't need lot of time to implement.
Date Time Of Last Edit: 2015-06-30 16:37:59
