Date/Time: Sun, 22 Dec 2024 18:05:01 +0000
Reverse Colors for Subgraph
View Count: 996
[2015-05-07 05:11:54] |
onnb - Posts: 662 |
In the subgraphs tab there is a checkbox called "Reverse Colors" for the Name and Value labels. Is there a way to set these with ACSIL? |
[2015-05-07 05:49:31] |
No, but we can add this capability.
[2015-05-07 07:04:08] |
onnb - Posts: 662 |
It is needed, if you can add that would be great.
[2015-05-07 07:27:56] |
OK.
[2015-05-07 16:15:14] |
onnb - Posts: 662 |
can I track this somehow to know when its available?
[2015-05-07 16:47:55] |
Yes. Just please check back in about a week.
[2015-05-09 23:31:18] |
This actually was already supported. It is now documented: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scSubgraph.html#scSubgraphLineLabel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
