Date/Time: Sun, 22 Dec 2024 18:00:20 +0000
Break even
View Count: 1138
[2015-05-07 02:08:33] |
User637121 - Posts: 3 |
Is there a manual "breakeven" button for sierra charts?
[2015-05-07 07:23:53] |
User63439 - Posts: 83 |
asked the same is the creation of a move-stop-to-break-even button (with a pre defined tick offset) possible? +1 |
[2015-05-07 23:36:38] |
SgtJ - Posts: 154 |
Been requested many times over the yrs. A separate scale out/in quantity too. Infinity use to offer 1 click stop adjustment on thier DOM, Jigsaw offers it now. No dragging order adjustments when scalping fast oil markets. SC should consider it. |
[2015-05-11 00:57:03] |
User52989 - Posts: 42 |
+1 can't see how this should be that difficult. Thanks in advance for consideration.
[2015-05-13 00:17:58] |
We will try to get this in very soon. We will try for next week.
[2015-05-15 10:17:07] |
A move to breakeven button has been added in the latest release: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1255 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
