Date/Time: Sun, 22 Dec 2024 16:10:27 +0000
Disappearing targets and stops on DOM
View Count: 981
[2015-05-06 20:09:09] |
Rob_2560 - Posts: 20 |
The ES DOM works fine, but my YM DOM shows the stop limit entry and the target and the stops, but the second the stop limit entry fills, the stop and the target disappear from the DOM. It leaves the user no way of knowing when the stop or target is going to get hit. What button do I need to press to keep the entry, target and stop visible on the DOM? I have searched around, not finding. Rob Slater (New user, only 3 days) |
[2015-05-06 20:11:07] |
What is the Status of those orders that disappear. You can find the status of them in the Trade >> Trade Orders and Positions >> Orders tab.
