Date/Time: Sun, 22 Dec 2024 16:26:45 +0000
Just need a pointer... spreadsheet to spreadsheet info transfer...
View Count: 933
[2015-05-06 16:46:58]
ArnulfoPenaloza - Posts: 7
Hi Support...
I just need a pointer...
Chart_1 has a spreadsheet called sheet_1 which has a column tracking whether LINE1 crossed LINE2.
Chart_2 has a spreadsheet called sheet_2 and I would like to pull in the column from sheet_1 into sheet_2.
Is this easily possible?
Thank You,
Arnie
[2015-05-06 19:52:49]
You cannot do this. But if both charts are using the same Spreadsheet window/container but different Sheets within a spreadsheet window, then the data can be referenced between them. Here is the format:
https://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#ReferencesOtherSheets
Date Time Of Last Edit: 2015-05-06 19:53:26
