Date/Time: Sun, 22 Dec 2024 16:35:54 +0000
Range bar to reflect volume
View Count: 998
[2015-05-06 12:59:31] |
User76939 - Posts: 11 |
Is there any type of range bar which can reflect the volume of the bar by the width of the bar? Thanks. |
[2015-05-06 19:49:32] |
For this you need to change the Graph Draw Type to one which includes volume: https://www.sierrachart.com/index.php?page=doc/doc_PriceGraphTypes.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
