Date/Time: Sun, 22 Dec 2024 16:40:47 +0000
Spreadsheet Study Updating
View Count: 1041
[2015-05-06 10:55:54] |
User16114 - Posts: 153 |
Currently I am clicking the "Insert" key to update spreadsheet study column "M" for a custom spreadsheet indicator. How can I get this indicator to update automatically? Using version 1250. The chart is a 30 minute candlestick chart with the Spreadsheet Study, where "K" column is "=BB3" and "L" and "M" are formulas. The formulas seem to be fine but currently I have to update them manually. |
[2015-05-06 10:59:21] |
BTW, column "BB3" is updating when I open the spreadsheet but column "K" which contains the formula "=BB3" is not updating in the spreadsheet.
[2015-05-07 08:58:28] |
but column "K" which contains the formula "=BB3" is not updating in the spreadsheet. This does not make sense. This is something very basic with spreadsheets and should not be a problem at all. So most likely we do not have a clear enough understanding of exactly what you are doing.In general we have insufficient information to help with this. Simplify this down to the most simple example which demonstrates the problem and provide a screenshot with commentary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
