Date/Time: Sun, 22 Dec 2024 13:33:54 +0000
Download Data - Historical Charts
View Count: 922
[2015-05-06 09:48:44] |
User659520 - Posts: 6 |
Good Morning, In previous SC versions it was possible to download all data files at one run. In the current version this option updates the current symbol only. What is the best way to update my 3000 symbol .dly files in one command? Thanks, Ronen |
[2015-05-06 10:15:35] |
Nothing has changed in this regard. How did you do this previously?
