Date/Time: Wed, 16 Sep 2026 23:29:16 +0000
volume profile all bars right justify
View Count: 1354
| [2015-05-05 19:05:58] |
| User231363 - Posts: 31 |
If I add a volume profile to a chart that uses 'all bars in chart', the profile appears to ignore the 'align to far right' setting. The profile's right side is anchored to the last bar on the chart. If I change the profile to a setting other than 'all bars on chart', it correctly positions itself to the right of the last chart bar. Am I doing something wrong, or is this a bug? thanks! |
| [2015-05-06 03:59:25] |
Update to the latest release of Sierra Chart.
